Liam's Z4C race car project
Looking good! Makes me miss going on trackdays. Great to see tracks are starting to reopen again, makes you think that racing behind closed doors wouldnt be too difficult... crowds arent that big for club racing anyways
- MrPT
Nice. So you’re getting on for Z4M power-to-weight now but obviously with a lot less weight (especially in the nose)?
N52 sounds great. Still a fantastic engine.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
Well done Liam. Great to be on track finally. Amazing how much you’ve done yourself to prep the car. Inspirational stuff.
Z4 Coupe 3.0si - Stratus Grey - M sport seats, headlining, New England, Carver, Cruise, Xenons, sT XTAs, Eisenmann race, 18” 405m
G21 M340i - Tanzanite - Tech Pack, Comfort + Pack, Visibility pack, pan roof.
- Vanne
Looks good man, sounds great. nothing fell off, thats a positive shakedown
is your rear sway adjustable? that might sort your turn in issue.
Powered by Severn Tuning
- MrPT
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Darkangelv2
The guy who did my interior has a coolerworx shifter. Very much rates it and it looks fantastic.
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
Coolerworx Ftw
- IMG_20190416_185705.jpg (159.84 KiB) Viewed 1368 times
- Silverzedtom
If it arrives
E85 2.5si
F55 Cooper S
F55 Cooper S
- Liam22
Thanks for the shifter suggestions. My current favourite is
https://www.garagistic.com/products/cha ... nt-shifter
Did an oil change today and I'm currently battling with a few issues:
1. Can't read oil level. I guess the sender is kaput
2. Got a couple of 2D06 codes from the air flow meter. Cleaned it and found one of the airbox spring clips missing which might be leaking air.
3. Radiator light comes on frequently, combined with 2E83 code. Ran the water pump bleed cycle a couple of times and topped up, but still there.
4. Shortly after I started the engine after refilling it just stopped. No coughing, no electrical issues, just stopped. Weird!
I've also ordered 2 new VANOS solenoids and new front brake pads... it's looking like an expensive month, so the shifter is on the back-burner!
- adam1985
Have you checked the sensor plug is connected ok at the bottom of the resevoir?
57 BMW 3.0si sport Coupe, Carbon Black, Bilstein B12 Suspension, CSL reps & style 339s for winter - Current
10 Skoda Fabia mk2 vRS, Rallye Green, Black Roof, Black Gigaro Alloys - Gone
08 Fiat Grande Punto Dynamic Sport, Red, Dual Sunroof - Gone
- Ed Doe
This is my rtd shifter (ignore disapproving doggo in the back - he doesn't like my Tillets )
Carbon Black '07 M Coupe: Intrax 1k2 Coilovers, AP-Racing, Raybestos ST45s, Tillets, Schroth, Vibratechnic, Apex EC7, Strongstrut, Eventuri, H&S, RTD, 4.1FD
Silver Grey '06 3.0si Coupe - SOLD
Great thread and a good read.
I’m looking for a 3.0i to strip and build into a race car so I’ll be popping back here for ideas!
Current - 2009 E91 330d M Sport Touring
Current - 2003 E85 Z4 3.0 Race Car
Current - 2011 R58 MINI Coupe Cooper S
Sold - 2006 E85 Z4M Roadster
Sold - 2004 R53 MINI Cooper S Race Car
Sold - 2004 E46 325ti
- Liam22
Autodoc are taking forever to ship the VANOS solenoids so I'm getting on with some minor jobs instead.
Replaced the washer bottle with a small kit car item. Doesn't look like much, but 450g saved
- Darkangelv2
And moved the weight backwards. Like it
- Liam22
Some more fiddling/ fine tuning.
Discovered that one of the brake cooling ducts had slipped off the bumper intake. The offside brake pads noticeably more worn as a result!
It is very difficult to attach the duct hose to the bumper so I decided to attach the duct to the front crash structure instead of the bumper. Took an insane amount of time to trim the ducts to match the interior contours of the bumper, but I can confirm that the bumper can now be removed in a couple of minutes now!
The facelift fog lamp holes are quite small but I've got the duct lined up nicely now
New VANOS solenoids are fitted and I've booked a rolling road power run for this Friday. With bhp and heat soak on my mind I decided to wrap the airbox in shiny aluminium tape to reflect some heat away. Might not be worth much in power terms but looks better than I expected.
