That spin near the start must have made you clenchLiam22 wrote: ↑Thu Aug 12, 2021 8:43 am Had a better outing at Silverstone International. P3 and fastest lap, but should have been an easy win.
https://youtu.be/fjR2_lro0Fc
After replacing the brake pads and bleeding again the brakes were fantastic. I'm just gonna be rely careful and only disable the steering angle sensor when on track.
I now have a leaky driveshaft. Keeps popping out of the diff by 10-15mm. Hoping it just needs a new snap ring.
Liam's Z4C race car project
Onlinebigwinn
EWS Delete PM me
Coding- airbags etc PM me
EWS Delete PM me
- 1536Z4
Definitely another close call in the earlier laps with the spinner and so close at the end .
Montego Blue E86 . MILV`s . Simpson Custom Manifold Race Exhaust . xHP transmission stage 3 . VT engine mounts . BC RA coilovers . H&R arbs . Adjustable rear camber arms . Ultra Racing front strut brace . Drexler LSD .
- Liam22
Got around to looking at this today. Unfortunately it's a right pain to remove the diff output flange:
1. Remove diffuser
2. Remove pull rod
3. Remove exhaust
4. Disconnect driveshaft from output flange
5. Disconnect damper lower mount
6. Disconnect upper wishbone from upright
7. Remove rear anti roll bar
And then remove the diff output flange!
As suspected, the snap ring was deformed and not holding the driveshaft in place.
Refitted as above and then topped up the diff oil. Needed more than I expected so the diff has run for a while with probably insufficient lubrication/cooling. Bugger. Let's hope it holds out.
- 1536Z4
A pain in the arse but had to be done . Now to get that diff oil topped up before the 26th
- enuff_zed
Hi Liam22, just checking, are you still heading to Snetterton in October?
Sunday 10th seems to ring a bell?
- Liam22
Haven't paid my entry fee yet. Ask me again at the end of the month.
- enuff_zed
No probs.
Won't book my ticket yet then.
- Liam22
Short update.
Final Roadsports race of the year last weekend. Back at Snetterton for the second time this year, and still carrying 10s success penalty. I had some great advice from a member on here about modifying the front splitter for a bit more front downforce. Car felt good in qualifying but didn't manage to put a proper lap together. Qualified 2nd in class B with quite a big gap to P1.
The race was better. Took the class lead at turn 2 and pulled out >10s gap before the pit stops. Kept the lead and took another class win with fastest lap, and set a new lap record for class B
https://youtu.be/tyP_Mg0yl_Q
You can see the splitter mod in this photo - vertical fences in front of the wheels.
You can also see that I'm missing a kidney grill.
Accidentally tapped a Porsche Cayman with epic turbo lag, as it failed to accelerate out of Oggies. The bumper took a bit of damage so removed it for repairs. Good job I did because otherwise I would not have noticed the coolant expansion tan is leaking. I'm going to assume it's the usual problem, so a new tank on order. Appears to be leaking from the lower heater connection. Where is the usual leak source?
I have one more race this year - BRSCC Clubsport Trophy at Anglesey supporting the Race of Remembrance in November.
- enuff_zed
Well done Liam, as it turns out I couldn't have made it anyway.
Shame as it seems you had a better day this time round.
So where do you stand in the results table for the year then?
- Liam22
Roadsports is just a series - no points, no overall winner.
Silverstone National: 1st
Brands Hatch: 1st (10s penalty)
Snetterton I: 5th (20s penalty)
Silverstone Intl: 3rd (10s penalty)
Snetterton II: 1st (10s penalty)
- 1536Z4
Good to see you continuing with success and the Z continuing with improvements . What are your plans for next season or is it too early to say ?
- enuff_zed
Well that will explain why I couldn't find it then.
Pretty good list there though. Well done.
- Sidewaze Samm
When is that? I may be on the island at the time, so if the weather is half decent might pop over.
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
- Liam22
- Vanne
Good results mate, nice job. Good to see your continued development of the car.
Can't wait to see what you do next season.
Powered by Severn Tuning
