Liam's Z4C race car project
Liam22
Post by Liam22 » Sat Feb 23, 2019 8:42 pm
Here's a build thread for my Z4 3.0si Coupe race car.
For the last 4 years I've been racing a Mazda RX8 in 750MC Roadsports and Club Enduro.
JonElsey750MC2018Birkett-755 hires mid.jpg (150.19 KiB) Viewed 3182 times
Before that I did 10 years in the Production BMW Championship (E30 320i).
Since the engine went pop in the RX8 last summer (after 30 races I might add) I've had an itch to go up a class in Roadsports. Always liked the Z4 coupe, and when I was searching the market for cars able to get to 240bhp/ton (@flywheel) it was by far the most interesting option. Not the cheapest though... I couldn't believe how much low mileage cars were going for.
Eventually I found this late 2007 example, with 107k miles on the clock and my ideal spec. No cruise, no satnav, no parking sensors. But piano black trim and nice wheels that I can sell to help fund the build. I paid £6500.
My plan for the build is this:
1. Brakes, suspension, bushes, all fluids, etc
2. Take it for a run around the Nurburgring while it's still road legal
3. Strip, roll cage, race safety equipment
I've decided not to take it back to a bare shell, mostly because it's just too much work. I do everything myself (except welding and painting) so I need to be sensible about how much I take on.
So let's get started!
Liam22
Post by Liam22 » Sat Feb 23, 2019 8:52 pm
Since the RX8 sold I've been researching upgrade options and stockpiling parts. There are parcels arriving every day at the moment!
The first job was a simple oil service. Had some difficulty getting the car safely up onto axle stands until I realised that the front crossmember is accessible after removing the undertrays. I'll be cutting a hole in the undertray for quick access to that jacking point before it goes back on.
While the engine oil was draining I inspected/cleaned the DISA valve and both VANOS solenoids. The sound generator is a hideous thing. I'm going to look into a direct hose from airbox to throttle body so that I can ditch the entire sound generator, but that can wait until I strip the interior.
The K&N panel filter got replaced with an OEM paper filter. I'd sooner replace the air filter every 6-7 races than worry about keeping the K&N properly oiled.
Liam22
Post by Liam22 » Sat Feb 23, 2019 9:04 pm
Next up, front suspension removal.
Things were going very well until I tried to remove the OSF brake disc. What sort of idiot re-fits a rounded-off, allen head, disc retaining bolt? I tried hammering in an oversized Torx bit, but the bolt was already cheese and it quickly became fully circular.
So out with the drill bits…
Other than that, everything else has come apart fairly easily. Although I'm having horrible E30 flashbacks of removing front control arm ball joints. Is there still no way of doing this without splitting the boots?
The tapered springs also meant that my spring compressors could only get hold of the middle coils which wasn't enough to take all of the tension off the damper. Thankfully, by the time I loosened the top nut off, it was almost out of tension and didn't explode :)
ARB is also off. I bought an E46 M3 convertible (27mm) item to go back on when the bushes arrive.
Just the steering rack to remove from the front end now. I want to remove the electric motor and run it as a manual rack to see if I can live with it like that. I can't see the motor though… where's that hiding?!
Online
Mr Tidy
Post by Mr Tidy » Sat Feb 23, 2019 9:36 pm
I'm going to enjoy reading how this develops!
Particularly looking forward to seeing how you sort the steering - I assume you're thinking of HPAS instead of EPAS? Or will you run it without PAS - might be OK on a race car.
My E91 has an N52 engine but HPAS, and it's just so much better than the EPAS on my Z4C so a conversion would be very tempting.
Coupes because stunning!
Current - Silver Grey MC, Imola Red heated Nappa & carbon trim. H & R Coil-overs, CSL Reps, Strut brace, Nav, cup-holders, DSP Hi-Fi, pdc, cruise, MFSW. E90 330i daily
Gone - Montego Blue
Gone - Ruby Black
buzyg
Post by buzyg » Sat Feb 23, 2019 10:34 pm
Good start. Interesting read too. Enjoy your new project. Especially :driving:
philbo909
Post by philbo909 » Sat Feb 23, 2019 10:43 pm
cracking project, looking forward to seeing how it goes on :thumbsup:
plenty of people on here would buy the sound generator of you I'd imagine. worth sticking it on.
the 19" wheels really dwarf the brake discs, they look so small, mine's only on 17" at the moment and they fill the wheel
Sapphire black z4 coupe 135,000miles young
Jembo
Post by Jembo » Sat Feb 23, 2019 10:45 pm
Great thread... looking forward to hear how you’ll get on... trust you know to poly the RTAB’s & maybe even add RTAL’s
Joined the dark side with a ///M Hell Bronze Sepang Coupe :happyclap:
Lifer 54
Doddsy
Post by Doddsy » Sat Feb 23, 2019 11:44 pm
Duck lake view put a post on Instagram under the zed shed recently about converting his EPAS. Might be worth asking him. :thumbsup:
Now:
E86 Z4C 3.0Si Sport Manual Silver Grey
Gone:
E85 Z4 2.5 Si M Sport Titan Silver
Online
Mr Tidy
Post by Mr Tidy » Sun Feb 24, 2019 12:29 am
Yes, but dlv has a pre-facelift so it has the M54 engine.
Liam22's Coupe is a facelift with the N52 engine, so it's not going to be quite the same.
Gone - Montego Blue
Gone - Ruby Black
Doddsy
Post by Doddsy » Sun Feb 24, 2019 12:36 am
My bad for some reason I thought DLV had a facelift car
Now:
Gone:
TomK
Post by TomK » Sun Feb 24, 2019 12:37 am
Definitely DON'T poly the RTABS would be my advice! Ruins the handling imo.
Limiters on oem rtabs yes.
I've done both back to back.
GuidoK will be along shortly to tell me I'm wrong no doubt.... :P
But really since #racecar the correct thing is to monoball it.
MC IB, CSL box, Schrick 288/280 cams, SS race bbox, APs, RS-29s, Apex ARC-8, A048, KW ClubSport, Turner arms & RTAB limiters, Vibratec mounts, Rogue pulleys & RSMs, Tillett B6 seats, UUC ssk, custom half cage
TomK
Post by TomK » Sun Feb 24, 2019 1:03 am
firebobby
Post by firebobby » Sun Feb 24, 2019 8:13 am
This looks interesting. You will get many ££££s back from interior parts, the seats will sell easy, multi function steering wheel, trim parts. All the removed parts will find new homes on here.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Jembo
Post by Jembo » Sun Feb 24, 2019 9:09 am
Another topic almost as divisive as Whippy vs Stubby or Couoe vs Roadster... polying the RTA’s change the way the @rse handles, some love, some loathe & some creak
Lifer 54
AveZ4coop
Post by AveZ4coop » Sun Feb 24, 2019 2:31 pm
Looks exciting, shall be following this with interest. :thumbsup:
Montego blue 2006 BMW Z4 coupe 3.0si with black interior, ZHP, Whippy, 12mm front/16mm rear spacers on BBS 108's wrapped in Michelin PS4's. :driving:Brand new Pierburg water pump fitted at 101k after failure :cry: (should have done it at 100k) :headbang:
