225/40 or 45 255/35 or 40?
As topic says, will it fit without problems or rubbing?
Want some extra clearance to my z4 3,0 -03
- Chris_D
needs clarity....?
What are you asking here?
- Mr Tidy
Yes, what wheels are you using?
225/40 x 18 front and 255/35 x 18 rears are the OEM tyre sizes on staggered 18" rims. Is your car lowered, or using spacers?
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- patriot66
I think maybe Torpalasse is asking can he increase the aspect ratio on the front from 40 to 45 and rear from 35 to 40 without any rubbing etc
- road warrior
i hope so cus that what im doing as well
the increase will raise the car by 1/2 an inch and increase the diameter by an inch
If you ever think I'm off my rocker.. Just put me back in it and walk away... It's the kindest thing
My wife says I never listen - or something like that.
gone but not forgotton -Mean Steve - made a sound like a bear with his nuts in a trap.
- philbo909
Obviously depends on the wheels/spacers you have, but if it's an oem set up you could change up to the sizes as you specify in the title.Torpalasse wrote: ↑Wed Jan 16, 2019 6:32 pm As topic says, will it fit without problems or rubbing?
Word of caution though, check your actual speed compared to speedo first.
Sapphire black z4 coupe 135,000miles young
- dhobbs
what are the ///M tyre sizes for 18 inch?
I know some people recommend them for the non-M
3.0si roadster. Requisite stubby. Sound gen mod. LED numberplate lights. LED boot strip. Interior lights LED too. ZHP gearknob. Daily drive
Motor in boot. Bilstein B8 dampers. New radio, much better sounds
- Zedtastic
I have just fitted (as in 20 minutes ago), 225/45-18 on the front and 255/40-18 to the rear. I've got standard Sport suspension and 5mm spacers at the front and 12mm at the rear. The off-sets are standard (ET 47 at the front and ET50 at the rear). So far there's no rubbing issues and all clears fine on full lock. I won't know if a bumpy road will cause rubbing problems, but I doubt it. Hopefully this helps answer the OP question.
F36 435d X-Drive (Daily)
E86 Z4 3.0Si (For dry weekends)
Focus RS Mk1 (In hibernation)
Escort RS2000 Mk2 (In hibernation)
Cortina Mk1, 2.5 turbo (In construction)
- mr wilks
Anyone with stock rims ( so 8.5j rears) considering upping the rear rubber to 255 40 should consider 245 40 as the best option , the 255 40 18 on Z4M style 224s are fitted to 9j rims .
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Thats exactly my question. No spacers, no nothing. But I ordered standard sizes today anyway. Goodyear eagle F1 assymetric 3.
On this subject I have a question. I have a 2005 3.0i with M sport suspension. 18" wheels with 255 rear tires (tyres) and 225 fronts. Are the front/rear wheels the same width/offset or different for each axle?
- mr wilks
Assuming your wheels are oem 18s originally made for your car then the rears are 8.5j (et50) & your fronts are 8j (et47)
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
