I had trouble removing the piston caps as I couldn't fit my hex bit + driver - the hex bit actually only JUST fit.
I ended up being able to loosen it with a wrench on the bit, then hand turned it out without the bit in place.
Thinking ahead, I realised when I reassemble I'll have the same problem in reverse.
So I went to the hardware store again to see if there was some sort of lower profile bit I could put on my driver but no luck
QUESTION:
How's everyone tackled this? My current option is to just tighten it finger-in-the-air with my spanner the same way I loosened it, though 50nm (37 ftb) seems pretty hefty to try and guess.
Any advice much appreciated!
