Went for the NCT today (Irish MOT) failed on the bonnet catch of all things. There’s a bit of a knack to getting it to close and the tester wasn’t in the mood to discover it
The mechanism moves freely and all that so I think that is ok. Does anyone know, could it be the front section cable causing the problem or is the lock just knackered and needs replacing? I assume there is no adjustment thingy anywhere?
I’ve googled all I can; most seem to struggle to open not close so any advice would be great thanks
Bonnet won’t close
- Coffee331
Bonnet won’t close
lubrication is your friend! As long as the catch ( in the slam panel ) returns back and the 'hook' on the lid itself is free, all should be good. May be a sticky cable, run some light oil down it, should be fine.
Ex E86 Z4 3.0si coupé facelift blue now Z'less
Porsche 997 C2S black-gone-, Mazda Eunos 1.8 yellow-gone-, Audi S4 Avant v6 Quattro 3.0 supercharged red-gone. Abarth 500 red. Abarth 124 Spider GT black. Porsche Cayenne red.
- buzyg
Bonnet won’t close
Does it have The three catches, or just one in the middle?
On mine I recall you can adjust the feet on the catch, of the two outside cathes by turning them. May be different on the ///M.
- Coffee331
Bonnet won’t close
Sorted healthy dose of penetrating fluid followed by a coat of grease and she sprung back to life
- kis
Bonnet won’t close
I had this on mine, latch was starting to seize up. Removed from bonnet and gave it a good clean, removed all the old grease as well. Then used some white grease on the spring. Loads better now!
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
