Well thank you sir
Lowering springs
- Marlon
Lowering springs
I had a facelift 3.0si with 19" wheels and changed the springs to Eibachs. The car looked absolutely stunning but the ride was far too hard for a daily driver. My commute was ok as I knew where all the potholes were but I used to dread having to drive anywhere new on dark and rainy nights where it's difficult to see the road.
Z4R 3.0si Sport auto. So far: 19" CSLs, Eibachs, MM exhaust tips, de-badged rear, stubby, black grilles, spacers, aux cable, interior LEDs, LED boot strip......
- Papa_Zee
Lowering springs
So I now need to decide on what to do with my 3.0 Si roadster. I use it every day to commute to and from work, @120 miles a day motorway and a/b roads and will do about 4 track days a year. The options;
1. New Bilstein B6 struts and keep the current springs.
2. New Bilstein B6 struts and new standard m-sport springs.
3. New Bilstein B6 struts and Eibach springs.
4. New Bilstein B8 struts and new standard m-sport springs.
5 New Bilstein B12 setup.
I'm not keen on Option 1 as I suspect that the springs, front especially, are quite tired. Option 2 gives the best comfort, if what I read is to be believed. Option 3 is the compromise option of softer struts but the "better"(?) springs? Option 4 doesn't seem to make sense as it's the harder struts and softer springs and Option 5 is the one that lots of people have gone for. There doesn't seem to he a great deal of difference in the price between any if the options. So I guess, in reality, it's really a straight fight between Option 2 and Option 5.
I know that everyone has their own opinion and they differ greatly from person to person but any great words if wisdom before I flip a coin?
My daily driver, and occasional track toy,
56 plate e86 3.0si sport.
Black
6 pot front brakes
B12 kit
Front and rear strut braces
Polly bushed
Short shift kit
90 miles and climbing, slowly.
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
- MACK
Lowering springs
Whatever choice you make Option 3 is pointless really from both a technical & financial point of view. The only difference between the B6 and the B8 is the shock rod length is reduced to suit lowering springs (namely Eibachs) with B8s. The compression and rebound characteristics are identical, all you'll achieve is some unnecessary reduction in travel/ preloading of the shock with a B6 over a B8. As the B12 kits (B8 & Eibach combo) tend to be really good value anyway it would seem pointless to buy Eibachs and B8 shocks separately.
What's not of your list are B4s paired with either SE, MSport or Eibachs, on a road going car, especially one doing the commute you do that would be my choice for a comfier setup than the B6/8 shocks. Cheaper too!
Silver 05 3.0i SE
White E89 20i M Sport
Lowering springs
MACK wrote: ↑Wed Dec 12, 2018 3:40 pm Whatever choice you make Option 3 is pointless really from both a technical & financial point of view. The only difference between the B6 and the B8 is the shock rod length is reduced to suit lowering springs (namely Eibachs) with B8s. The compression and rebound characteristics are identical, all you'll achieve is some unnecessary reduction in travel/ preloading of the shock with a B6 over a B8.
I hadn't realised that the difference between the B6 and B8 was just the rod length,. I thought the rod length difference was between the B4 and the B6/B8 with the former being longer for SE / M-Sport springs and the latter for the lowered ones.
True if the B6 and B8 are only different in rod length then the B12 kit makes perfect sense.
I hadn't looked at the B4s as I thought that they were too short for the standard M-Sport springs. I've not noticed that the price of the B6/8 being very different.
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
Lowering springs
If I went for the B4 M-Sport option would it be worth upgrading the anti-roll bars for the track? The track will be reasonably smooth, so the spring damper arrangement is less important except for roll in the corners, but the softer setup would be better for the commute where the anti-roll bars have less effect.MACK wrote: ↑Wed Dec 12, 2018 3:40 pm Whatever choice you make Option 3 is pointless really from both a technical & financial point of view. The only difference between the B6 and the B8 is the shock rod length is reduced to suit lowering springs (namely Eibachs) with B8s. The compression and rebound characteristics are identical, all you'll achieve is some unnecessary reduction in travel/ preloading of the shock with a B6 over a B8. As the B12 kits (B8 & Eibach combo) tend to be really good value anyway it would seem pointless to buy Eibachs and B8 shocks separately.
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
- philbo909
Lowering springs
If you're tracking it, you might as well get some coiloversJonLeeper wrote: ↑Wed Dec 12, 2018 4:01 pmIf I went for the B4 M-Sport option would it be worth upgrading the anti-roll bars for the track? The track will be reasonably smooth, so the spring damper arrangement is less important except for roll in the corners, but the softer setup would be better for the commute where the anti-roll bars have less effect.MACK wrote: ↑Wed Dec 12, 2018 3:40 pm Whatever choice you make Option 3 is pointless really from both a technical & financial point of view. The only difference between the B6 and the B8 is the shock rod length is reduced to suit lowering springs (namely Eibachs) with B8s. The compression and rebound characteristics are identical, all you'll achieve is some unnecessary reduction in travel/ preloading of the shock with a B6 over a B8. As the B12 kits (B8 & Eibach combo) tend to be really good value anyway it would seem pointless to buy Eibachs and B8 shocks separately.
Sapphire black z4 coupe 135,000miles young
Lowering springs
Except I'm tracking it 4 times a year and commuting in it every day. Also decent coilovers are £2,500 and the Bilstein B12 set is £700.philbo909 wrote: ↑Wed Dec 12, 2018 4:06 pmIf you're tracking it, you might as well get some coiloversJonLeeper wrote: ↑Wed Dec 12, 2018 4:01 pmIf I went for the B4 M-Sport option would it be worth upgrading the anti-roll bars for the track? The track will be reasonably smooth, so the spring damper arrangement is less important except for roll in the corners, but the softer setup would be better for the commute where the anti-roll bars have less effect.MACK wrote: ↑Wed Dec 12, 2018 3:40 pm Whatever choice you make Option 3 is pointless really from both a technical & financial point of view. The only difference between the B6 and the B8 is the shock rod length is reduced to suit lowering springs (namely Eibachs) with B8s. The compression and rebound characteristics are identical, all you'll achieve is some unnecessary reduction in travel/ preloading of the shock with a B6 over a B8. As the B12 kits (B8 & Eibach combo) tend to be really good value anyway it would seem pointless to buy Eibachs and B8 shocks separately.
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
Lowering springs
I'll be honest, I've thought long and relatively hard about this.
It's getting B4s and standard springs. One of my biggest gripes with the car is the ride quality, and truth be told I don't want to be in the position of investing more money and ending up with more backache than I already have. A few of my favourite roads are simply undriveable as it is - I mean, I can get from A to B, but not at any real pace.
As another upvote for B4's, I have them on the front of my road rally car, and they actually work really well on that. Not a Z4, but something to consider.
But. Your views may vary. Mine's never going on track, just down Hampshire's rutted broken road surfaces.
E86 | Stratus Grey
- philbo909
Lowering springs
Then I recommend bilstein b4 and msport springs (basically an oem refresh) for £200-£300, mime was night and day compared to old shocksJonLeeper wrote: ↑Wed Dec 12, 2018 4:14 pmExcept I'm tracking it 4 times a year and commuting in it every day. Also decent coilovers are £2,500 and the Bilstein B12 set is £700.philbo909 wrote: ↑Wed Dec 12, 2018 4:06 pmIf you're tracking it, you might as well get some coiloversJonLeeper wrote: ↑Wed Dec 12, 2018 4:01 pm If I went for the B4 M-Sport option would it be worth upgrading the anti-roll bars for the track? The track will be reasonably smooth, so the spring damper arrangement is less important except for roll in the corners, but the softer setup would be better for the commute where the anti-roll bars have less effect.
- Silverzedtom
Lowering springs
The above pic is with two heavy suitcases in the boot but you can see why I wouldn’t want to go much lower.
All in all it sounds like you might be better off putting it off for a year or so and saving the pennies for coilovers if possible, a lot of money but the only real solution for spot on damping and a lower car imo.
E85 2.5si
F55 Cooper S
F55 Cooper S
- Sideways Steve
Lowering springs
For reference, I have the Eibach Pro Kit springs on my Z4 with MSport shocks, 18" Rims with NON Runflats and the ride is really nice.
I also have the Eibach's and MSport shocks on my E91 Touring with similar tyre & wheel combo and again the ride is spot on.
The Mini has the JCW shocks with the Eibach pro kit, 18" JCW rims with non-runflat tyres and is a little bit harsh on really bad roads but even using it daily its perfectly comfortable.
I guess my point is, 3 different cars but essentially the same spring/shock/tyre & wheel combination on them all and don't have any issue with ride quality.
- Z4 Eibachs.jpg (292.36 KiB) Viewed 844 times
2004 E85 Z4 Roadster
2007 E91 Touring
2007 R56 Mini JCW (Currently For Sale)
2007 E91 Touring
Lowering springs
Because you have a back made of steel.
And quite a nice coloured car.
E86 | Stratus Grey
Lowering springs
So it's either stock M-Sport springs and B4s or Eibach springs and B4s!Sideways Steve wrote: ↑Thu Dec 13, 2018 1:31 pm For reference, I have the Eibach Pro Kit springs on my Z4 with MSport shocks, 18" Rims with NON Runflats and the ride is really nice.
I guess if I go for the Eibachs I can always revert to my current tired M-Sports or upgrade to B8s if I want to change!
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
Black
6 pot front brakes
B12 kit
Polly bushed
Short shift kit
