Quick + Easy Headlamp improvement please?
- derin100
I'm actually going to be using my E85 3.0Si a bit more this winter. I brought it out of storage in Shropshire yesterday and drove it back to Lincolnshire. It was an evening journey and I really noticed just how poor the standard (non-Xenon) lights are on this car and it's pretty dark countryside around where I now live.
Previously, to other cars like E38s and E39s, I have just fitted those relatively cheap 'Night Eye' bulbs that you can buy on Ebay for about £17. Although I'm aware they're not strictly legal, they did their job quite well actually with no particular problems and come MOT time I'd just change them back out again temporarily.
With the E85 however I'm not sure I could use a set of these as the cooling bit at the back probably won't allow the back cover on the headlamp assembly to go back on.
What relatively quick and easy solutions for improvements do forum members recommend? I don't really have the skills (or patience these days) to do complex electrical installations.
Thanks in advance!
Thanks in advance!
E85 3.0Si Silver on Black (Gone and will be missed)
E85 M Roadster Silver Grey on Black
E85 Alpina Roadster S Toledo Blue on Black
Hi
I’ve used the Osram Nightbreaker bulbs to good effect, had them in my E46 and my TR6 and the lighting is much improved.
Cheers Kev.
2005 Titan Silver BMW Z4 E85 2.0SE
2013 Graphite BMW 120d Sport
1972 Pimento Red Triumph TR6 2.5 Pi
1979 Azzurro Blue Lancia Beta Coupe 1.6
- derin100
Thanks Kev, I used them in the passed as well on other cars. I might even have some in the garage. So, I might try them temporarily.
I'm just wondering if anyone had found a 'Night Eye' type LED bulb that fitted the Z4...as they really are a MASSIVE improvement!
- Greg 01
+ 1 for the nightbreakers
Big improvement on the country roads
Nachtblau metallic 3.0 si auto ,cup holders , whippy back on
- derin100
I think that's going to be the quickest, easiest way and no issues of legality.
Cheers chaps!
Cheers chaps!
Hi
I’ve used this https://www.classiccarleds.co.uk/search?q=LLB477 company for LED dash light for my TR6 but not for headlights. Worth checking them out.
No connection, just a happy customer.
Cheers Kev.
- chrisgreen
i've got the halogens which were terrible in the dark - i just adjusted the beam upwards by about half a turn and this helped alot
'04 E85 Z4 3.0 silver/black - daily driver - Sold
'02 E46 M3 PY/Kiwi
'05 E46 330d Touring - Silver Grey/Black
'02 E46 M3 PY/Kiwi
- derin100
Those are like the 'Night Eye' ones I was talking about Kev (only you can get the much cheaper than the price they're advertising). The do make a huge difference but the problem in the Z4 is that the back of those bulbs is over 4cm proud of where the bulb inserts. So I don't think the black plastic cup that seals of the bulbs at the back in the Z4 will fit over them.Kevoz4 wrote: ↑Tue Nov 06, 2018 2:47 pm Hi
- derin100
That's a good little trick Chris! I may give that a go as well.chrisgreen wrote: ↑Tue Nov 06, 2018 3:09 pm i've got the halogens which were terrible in the dark - i just adjusted the beam upwards by about half a turn and this helped alot
In the meantime, I've also ordered a couple of pairs of these:
https://www.ebay.co.uk/itm/OSRAM-Night- ... 0005.m1851
Thanks chaps!
I have the night eye h7 LED's, Theres loads of room for the back cover. Its not even remotely close.
Much better than any halogen. I wouldnt even think about going back to halogens, Especially when every other modern car has high mounted laser beams installed directly into your eye.
Take out the projector assembly (4 nuts) and give it a clean, I was surprised how much fine dust there was on the lens
E85 3.0
- Silverzedtom
Another vote for nightbreakers here although I found I still needed to adjust the beam angle upwards. I put them back for mot day just incase...
E85 2.5si
F55 Cooper S
F55 Cooper S
- kis
Are your lenses clear? With age they discolour and get slightly cloudy. You can restore them with kits that are easily available
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
I bought the Philips X-tremeVision (+130), they've made a big difference. Fairly well priced on Amazon too:
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
I've also bought a headlight restore kit, but haven't got to that yet.
Also Amazon..
Also Amazon..
- NickDE
I'm also on the Philips X-tremeVision (+130), make a big difference for my two hour commute only mainly unlit country roads.
Darkness gone, go Darknes2, go Frozen, go Tronic
