Solar battery charger
As it says on the tin,looking for recommendations as no power in garage ,also is it wise not to use the ones that plug into the ciggy lighter
- NickDE
I use one on my E46 which has an ability to drain it's battery in two weeks. I use a ciggy lighter one, just unplug it before starting the engine.
Go for a larger, more powerful, more expensive one.
Darkness gone, go Darknes2, go Frozen, go Tronic
- tomoz4white
A friend of mine with a Audi TT (yes he likes hairdressing) uses a Solar Powered pack and says it works a treat.
Not sure how much he paid for it but can find out if you are interested.
Only UK OEM White Manual
E85 3.0i SE Still Rolling!
Mileage 36,000 Miles
4 x White 3.0i OEM UK E85's Made...
= 2 UK Pre-Facelift / 2 UK Facelift
Cheers Tomoz that would be good,you get wot you pay for seen some cheap ones but recommendations always welcome
- buzyg
A man who drives a white Z4 roadster actually wrote this.tomoz4white wrote: ↑Sat Oct 27, 2018 10:28 am A friend of mine with a Audi TT (yes he likes hairdressing)
Get that wing fitted at once.
My mate DARREN who is on here has the hairdressers version,when I met him years ago he had loadsa hair like me after suffering the hairdressers car his hair is falling out so it just goes to prove that convertibles make yer hair fall out,eventually
- tomoz4white
His TT isn't white so maybe he is "less hair dressy" than most Z4 drives afterall!buzyg wrote: ↑Sat Oct 27, 2018 11:59 amA man who drives a white Z4 roadster actually wrote this.tomoz4white wrote: ↑Sat Oct 27, 2018 10:28 am A friend of mine with a Audi TT (yes he likes hairdressing)
- kis
I bought one from the AA Essentials range. Plugged into the OBD port. Don’t know if it works or not? Still in the testing phase and recently the battery died again, so seemly doesn’t. Possibly just the connection? Again still in the testing phase.
So I’ve got another one on order which charges through the ciggy port and is supposed to be a heavy duty one. So let’s see how this one fairs!
Interested if someone has one which defo works, robust, etc.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Read that someone used the ciggy lighter port and it blew a fuse
- BeeEmm
I believe that having a roadster is enough to qualify. The colour is irrelevant.
I used to have two boys and a girl. Now I have two Men and a Woman.
- buzyg
- tomoz4white
My TT Friend (yeh the one with the hair dryer - lol) said he purchased his from Maplins but it was similar to this:-
https://www.care4car.com/12-volt-electr ... 9a8_ZP7SM8
He said it works a treat although he did rig it to the battery and doesn't use the Ciggy Socket.
Hope that helps
Tomo
Hope that helps
Tomo
- Smartbear
I’ve got one of those from maplins, obviously not as good as a mains powered unit but I plug it into my 125cc Suzuki and it seems to keep that happytomoz4white wrote: ↑Mon Oct 29, 2018 8:57 am My TT Friend (yeh the one with the hair dryer - lol) said he purchased his from Maplins but it was similar to this:-
Hope that helps
Tomo
e85 3.0si sold
- kis
Are there any issues with using the ciggy port?
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Usel
For the past 15 years I have looked after a large car collection and I charge all the cars on a trickle charger using the lighter sockets.
The chargers only pump out up to 3a and never had a problem. I can't see a solar panel putting out more than that so should be ok.
