Where would i obtain thicker spring pads? Also would these not take away some of the reduction that i wouldve gained by lowering it in the first place?z4pilot wrote: ↑Fri Oct 26, 2018 11:16 amDrop it on eibachs all round, but use thicker spring pads at the front to bring it back to the gap you prefer - that way you'll hopefully avoid the front rubbing, which you will get if you drop it at the front with those offsets.the stripler wrote: ↑Thu Oct 25, 2018 8:08 pm What tyres are you running o.p
Ive just added 19s myself on 225 30 19 and 265 30 19.
Cant decide whether to drop the rear only, as front is perfect or up the rear profile a little to 255 35 19
viewtopic.php?f=3&t=94254&p=1386513&hil ... s#p1386513
Lowering Springs Advice
Bmw Z4 2.5 Si, Hellrot Red, Style 224s, Zorst tips, Cupholders,
SEAT Exeo ST170, superchipped to 215hp.
Audi A3 S-Line.
Honda SP2 S4.
1984 Mongoose Supergoose.
http://i1206.photobucket.com/albums/bb4 ... 0cpufq.jpg
Audi A3 S-Line.
Honda SP2 S4.
I purchased mine from Amazon and came direct from Germany in just a couple of days. I've got an e89 and this is how it sits on Eibachs:the stripler wrote: ↑Fri Oct 26, 2018 7:46 pm Ok....
Think I'll give it a whirl then.
Wheres best place to get them. I see them on fleabay but wondered if theres anywhere thats recomended
You can see in my sig (until I update it) how high it originally looked.
- MrPT
If you're really not bothered about a firm/harsh ride, then go for the Eibachs. The drop is perfect and you'll never know what the ride is actually like till you try them for yourself (millions of conflicting reports on here!).designoutlaws wrote: ↑Mon Oct 22, 2018 5:20 pm I currently have a 56 plate 2.5si on 19" 'CSL' Wheels and I was wondering what would be the best option in terms of just getting rid of the arch gap really. Im not bothered about a firm/harsh ride, just don't want to deal with rubbing issues
Any advice would be appreciated on brands etc.
Cheers, Matt
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- z4pilot
BMW dealer for the spring pads and yes it would reduce the drop - but you said the front arch gap is perfect as is, so thicker pads would achieve that whilst maintaining the matching spring rates front and rear.the stripler wrote: ↑Fri Oct 26, 2018 7:48 pmWhere would i obtain thicker spring pads? Also would these not take away some of the reduction that i wouldve gained by lowering it in the first place?z4pilot wrote: ↑Fri Oct 26, 2018 11:16 amDrop it on eibachs all round, but use thicker spring pads at the front to bring it back to the gap you prefer - that way you'll hopefully avoid the front rubbing, which you will get if you drop it at the front with those offsets.the stripler wrote: ↑Thu Oct 25, 2018 8:08 pm What tyres are you running o.p
Now Gone - 2008 Coupe, Montego Blue, Champagne leather and Piano Black interior, Eibachs & Koni Sport shocks, Style 230 19s, Eisenmann Quad - approaching perfection...
Is there any way to check if it has replacement springs.. cars done 45k now so it is a possibilitywarmasice wrote: ↑Fri Oct 26, 2018 3:19 am I bet at some point, none progressive after market (not quite OE) rear springs were fitted. Perhaps after the tips cracked.
Your rear looks way too high, I'd suggest getting some Eibachs pro springs and fitted. You could do just the rears but fitting them all round will look spot on.
Audi A3 S-Line.
Honda SP2 S4.
Audi A3 S-Line.
Honda SP2 S4.
Yep, some of the aftermarket ones aren't progressive (spring is the same thickness tip-to-tip). The factory ones are thinner at the tips and also have distinctive markings. A quick Google should show you what these look like.the stripler wrote: ↑Tue Oct 30, 2018 9:56 amIs there any way to check if it has replacement springs.. cars done 45k now so it is a possibilitywarmasice wrote: ↑Fri Oct 26, 2018 3:19 am I bet at some point, none progressive after market (not quite OE) rear springs were fitted. Perhaps after the tips cracked.
Ooh thats interesting, i checked the springs and they are same thickness the whole way
Audi A3 S-Line.
Honda SP2 S4.
Audi A3 S-Line.
Honda SP2 S4.
Just as I suspected then! Now go purchase those Eibachs and get yourself a good looking stance. You definitely have a better ride too, especially with them being progressive.the stripler wrote: ↑Sun Nov 04, 2018 7:44 pm Ooh thats interesting, i checked the springs and they are same thickness the whole way
