Wheel/tyre advice needed
Just bought a set of wheels and tyres off forum member. First time upgrading to 19s so need advice.
The fronts are 8.5j et35 with 225 35 19 hankook evo s1 tyres on around 5mm
The rears are 9.5j et38 with 265 30 19 Roadstone n8000 with around 6mm of tread all over.
Will these fit straight on with no issues or will adjustments be neccesary.
Car is 2.5si and i currently have 18s on with spacers on rear.
Will the car sit the same or am i gonna have to lower it, so it doesnt look silly? Prefer not to lower it if im honest. And will tracking need redone.
Any advice appreciated
Bmw Z4 2.5 Si, Hellrot Red, Style 224s, Zorst tips, Cupholders,
SEAT Exeo ST170, superchipped to 215hp.
Audi A3 S-Line.
Honda SP2 S4.
1984 Mongoose Supergoose.
http://i1206.photobucket.com/albums/bb4 ... 0cpufq.jpg
Audi A3 S-Line.
Honda SP2 S4.
I’ve been informed the standard sizes fitted are -
8j et 47 front
8.5j et 50 rear on non M
If you use ,https://www.willtheyfit.com you can compare old and new sizes
You need to consider the ‘poke’ and ‘inset’
8j et 47 front
Current - Z4 MC, M3 CSL, S54 Z3MR, Z1.
OnlineMr Tidy
Yes, but they are 18s so using that link is probably a good plan.Gazza51 wrote: ↑Thu Oct 04, 2018 8:18 pm I’ve been informed the standard sizes fitted are -
8j et 47 front
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Sorry guys im confused even more..
Can anyone explain it in simple terms
Audi A3 S-Line.
Honda SP2 S4.
Audi A3 S-Line.
Honda SP2 S4.
Go to the website mentioned
Enter you existing tyre and wheel size
Enter the new tyre and wheel size
Hit calculate
The results will be shown on the left and a description below that.
Hit calculate
- LittleZ4
As above!!
If you're struggling, what size are your current tyres?
3.0i Maldives blue, Coilovers, Bola B1's, Buckley06 Gear knob, Handbrake & Indicator badges, Backbox delete, CDV delete, cupra r splitter, RAM air filter, Bigger Brakes, M3 ARB, SMF.
just tried it, just don't know the ET sizes etc. All I know is when I bought them they were staggered
Audi A3 S-Line.
Honda SP2 S4.
Audi A3 S-Line.
Honda SP2 S4.
- LittleZ4
Try using the ET's mentioned above.
I found the for sale thread for the wheels which includes pictures, he says they fit nicely on a Z4 Coupe.
viewtopic.php?f=7&t=109552
OnlineMr Tidy
OK OP, here are the results.
For your fronts:- https://www.willtheyfit.com/index.php?w ... offset2=35
For your rears:- https://www.willtheyfit.com/index.php?w ... offset2=38
So it looks like your new wheels will clear the suspension OK, but will sit a lot further out than OEM wheels. (18.4 mm on the front and 24.7mm on the rear).
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Thanks mrtidy
So im guessing thats an acceptable difference?.
Either way i think the pictures look great.
Audi A3 S-Line.
Honda SP2 S4.
Audi A3 S-Line.
Honda SP2 S4.
OnlineMr Tidy
Yes, I just found the Sale thread!
If they fit an E86 they'll fit and E85 - and look great too!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Cheers m8
Audi A3 S-Line.
Honda SP2 S4.
Audi A3 S-Line.
Honda SP2 S4.
- Steve84N
Those offsets will stick out by around 5mm too much.
Definitely rubbing territory unless you're running high suspension and don't corner aggressively.
C63 AMG Estate 6208cc
Well, wheels are on and look great.
In the end they sit flush with the arches. Not sitting out or in......perfect
Audi A3 S-Line.
Honda SP2 S4.
Audi A3 S-Line.
Honda SP2 S4.
