Gearbox oil
Kierandc5
Gearbox oil
Post by Kierandc5 » Tue Oct 02, 2018 2:04 pm
2006 3.0si what's people's opinions on oil. Should I replace with standard factory oil or use upgraded oils car booked in Thursday for a service
patriot66
Gearbox oil
Post by patriot66 » Tue Oct 02, 2018 2:20 pm
I put Castrol Syntrans B75W (API GL-4, ZF TE-ML 11) in my gearbox April 2017. Quieter and much smoother changes. No complaints and would definitely use the same again :thumbsup:
'03 Sterling Grey 2.5i SE / SMG / Matching Hardtop / Gloss Black MV3s / Bilstein B4s / DLV Backbox / Carbon-wrapped Interior Trim / Re-Covered Steering Wheel / De-tango'd !
Kierandc5
Gearbox oil
Post by Kierandc5 » Tue Oct 02, 2018 3:21 pm
Perfect silly question how many litres will I need
mjennings23
Gearbox oil
Post by mjennings23 » Tue Oct 02, 2018 4:12 pm
Used Miller's 75w80 myself, again perfectly smooth changes.
Factory spec is a 75w80 oil that meets GL4 specifications, so stick with that and you won't go wrong. Quantity is roughly 1l. Best bet is to buy 2 1l bottles, that way you won't be caught short but could return one if you don't need it?
Online
Zoomer
Gearbox oil
Post by Zoomer » Tue Oct 02, 2018 4:14 pm
Opie oils will normally be a good place for info.
https://www.opieoils.co.uk/
Silver 3.0i Z4 now gone
Grey 3.0i E85 Black Heated Leather M sports seats , 224's ,Sat Nav, Bluetooth, Xenons, PDC, Gaptech ,Intravee ,Cruise and a nice warm garage.
Kierandc5
Gearbox oil
Post by Kierandc5 » Tue Oct 02, 2018 6:18 pm
Perfect guys thanks for the info
Kierandc5
Gearbox oil
Post by Kierandc5 » Thu Oct 11, 2018 8:38 am
Just an update has the gearbox oil done and what a difference it has made. My gearbox was quite notchy but now its a real pleasure
Online
tadekk
Gearbox oil
Post by tadekk » Thu Oct 11, 2018 8:48 am
Which oil did you end up using?
Kierandc5
Gearbox oil
Post by Kierandc5 » Thu Oct 11, 2018 9:29 am
Just ended up using the Bmw specific. My bmw indy gets huge discount on it. Might not be the best oil going compared to others mentioned but the difference is night and day
Silverzedtom
Gearbox oil
Post by Silverzedtom » Thu Oct 11, 2018 12:55 pm
What mileage are you on? I’ve been thinking now would be a perfect time to change mine at 44k
2.5Si sport titan | Syrah blue interior | CSL reps | ZHP gear knob | Eibach pro kit springs | CDV delete | Wiechers racingline strut brace | Ram air scoop | Matt grill | Blue Calipers | de-badged | muffler delete | K&N | CF skirt extensions | Stubby
Kierandc5
Gearbox oil
Post by Kierandc5 » Thu Oct 11, 2018 2:40 pm
Wow that's low mileage mine is just past 95,000 miles. I would get it done as its pretty cheap. I was charged 120 for gearbox oil, engine oil, oil filter, suspension check and a full diagnostic in my mind I have fallen in love with the gear changes
