Winter Running
Winter Running
I don't have the benefit of a garage (or at least one i can get the car in) or the inclination to take it off the road for the winter months and as a result I will be running it through the winter - it has a nearly new set of Pirelli P Zero's on and I won't be running it when the snow is on the road.
Do I need to invest in a set of winter tyre's and an outdoor cover or just exercise caution and maintain the cleaning / waxing routine?
Sapphire Black 23i
Previously 7xZ3's, 5xE85's, 2xE86's & 3xE89's
- MrPT
Winter Running
Where do you live and is it your only car?
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
- Sidewaze Samm
Winter Running
My experience of those tyres in temps below 10deg C is not good at all - not a lot of grip. Luckily never experienced snow with them.
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
Winter Running
I'm based in Sheffield and I also run a SAAB 9-3 and Chrysler Grand Voyager MrPT
Sapphire Black 23i
Winter Running
I’d suggest you look at all season tyres rather than have the hassle of swapping winter wheel/tyres twice a year.
08 Z4 3.0si Sport Coupe in Montego Blue
- ph001
Winter Running
If you don't intend on using it in the snow then P zero's will be fine over winter in this country. I had them on my Z3M and did several winters with no issues. Obviously you need to be aware of the reduced grip levels when they are cold.
Buy yourself some ACF50 and give the underside of the car a good spray (particularly the brake pipes). Amazing stuff.
- Jembo
Winter Running
It’s worth searching the many threads on this subject.
It’s not the snow that’s the issue, it’s ice, especially black ice where winters make a real difference
Lifer 54
Lifer 54
Winter Running
I've run my E86 (and a number of other cars/vans) with and without winter tyres. In my experience it's definitely better to have them in icy conditions.
Bear in mind though that the Z4's limited ground clearance means running in snow might present a different set of problems which winter tyres won't resolve.
Start the day with a smile, get it over with.
Bog standard 2007 3.0si manual E86 in Montego blue with black leather, currently fitted with MV2s
- Steve84N
Winter Running
Don't do this. They are compromised for more of the year than the amount of time they are better than summer tyres.rally-chris wrote: ↑Tue Sep 18, 2018 8:07 am I’d suggest you look at all season tyres rather than have the hassle of swapping winter wheel/tyres twice a year.
I ran my Z4 through winter on summers no problem and it's only snow that it was poor in. I had a Quaife though so still managed alright.
C63 AMG Estate 6208cc
- Mr Tidy
Winter Running
I've put winters on my E46 daily for the last 3 winters, and it was so much better when temperatures were low, especially on damp roads.
This year I replaced it with an E91 just in time for the Beast From The East, but as it came on winters I had no problems.
If I was running my Z4 as a daily through the winter I'd want winter tyres on it - just in case!
I wouldn't bother with a cover - my Z4 lives outdoors all year with no ill effects. I have seen rubbing of the paint on the extremities (like front & rear wings) of covered cars due to the covers shifting if it gets windy.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Winter Running
I’ve just fitted a set of Eagle F1s and I intend using it through the winter, not in the snow or icey conditions as I have a main car but not going through the hassle of changing tyres or buying a second set of wheels.
Will chose whether to use it depending on the road conditions.
Toys: Z4 E89 35i in Blue / Ducati Multistrada 1260 DVT + love my watches
- skelters
Winter Running
I drive mine all year round and I'm further north than Sheffield thankfully.
Car will be fine.
Tyres will be fine.
Make sure you keep a hat and a jacket in the boot for those days when you can get the roof down over the winter.
Sunglasses too!
Roof down
Bum warmers on
Heating to the floor
Sorted!
Car will be fine.
Tyres will be fine.
Sunglasses too!
Roof down
Bum warmers on
Sorted!
2007 Z4 3.0si Sport. Silver Grey Metallic, Brembo Brakes, HEL Braided Brake Hoses, Machine Monkey Exhaust Tips, Stubby, Piano Black trim, Black Leather, Bilstein B12-Pro-Kit, Michelin Pilot Sport 4 on MV2's. Roof Motor in the Boot!
- buzyg
Winter Running
As you have alternate vehicles for when weather is really poor, I would stick with the summer tyres and just not drive the Zed on those days.
Winter Running
I live about 20 miles from Sheffield albeit on the other side of the Pennines
No amount of “ winter tyre” will get you anywhere in the Z if conditions are bad.
Winter tyres are great, I’m an advocate of them but if you have anything like the weather we do then I wouldn’t bother with the expense ..
Pic of our main road, it was around 8ft deep at the time ..
- 1CB9A184-9C93-4379-9415-96262C18FF0A.png (772.57 KiB) Viewed 779 times
Winter Running
Ah, yes. Winter. I remember that.
- P9110017.jpg (537.33 KiB) Viewed 777 times
