So I’m replacing my front rotors and pads as the discs have warped - even though they have hardly worn down (only 3000 miles on them).
Do I still need to replace my brake wear sensors? They have not gone off or anything.
Can the be re-used - without them going off prematurely. The front pads literally have only worn down about 10% maybe 20% at the very most.
Brake wear sensor
- shuey
Brake wear sensor
M2 OG / Manual / Grey
Previous
Z4C Si Sport / Manual / Alpine White
350Z VQ35DE / Manual / Silver
Seat Leon Cupra MKII / Manual / Silver
Ford Puma 1.7
Rover 214 Si (I know!)
Previous
Ford Puma 1.7
Brake wear sensor
Re-use
- Ducklakeview
Brake wear sensor
As above, fine to re-use. Make sure you don't break it pulling it out, and that you also get the small U shaped retaining spring which normally stays lodged in the edge of the brake pad, you need to put tat back in place on the sensor end before pushing it back into new pad.
Mike
Mike
- shuey
Brake wear sensor
Cool thanks guys
Previous
Ford Puma 1.7
Previous
Ford Puma 1.7
