585mm
Would you say been lowered
- CHIMV8
- patriot66
If that is an early car on its original Sachs shocks then they may well be contributing to the low ride height. I have an '03 SE that used to sit very much like yours CHIMV8 until I recently replaced the original and VERY goosed shocks with a set of Bilstein B4s. It now sits 10-15mm higher. Do I care ? No because it handles and rides SO much better.
- CHIMV8
TBHpatriot66 wrote: ↑Mon Aug 20, 2018 9:25 pm If that is an early car on its original Sachs shocks then they may well be contributing to the low ride height. I have an '03 SE that used to sit very much like yours CHIMV8 until I recently replaced the original and VERY goosed shocks with a set of Bilstein B4s. It now sits 10-15mm higher. Do I care ? No because it handles and rides SO much better.
No knowledge of the car other than service history and comments from previous owner,and what i am slowly discovering over the last month sine i bought her
Taking in all your comments i have received on various threads,and going to change/upgrade/renew a lot on the car
Rebuilt over a number of years 2 TVR Chimaera's 4.0L and 5.OL and cant leave the itch alone
Never thought i would take to a Z4 but i have to say i love it
Have you a link to the shocks that you mention
Mark
Sterling Grey 3.0
- Z4C_er
- patriot66
Fronts :CHIMV8 wrote: ↑Mon Aug 20, 2018 10:10 pmTBHpatriot66 wrote: ↑Mon Aug 20, 2018 9:25 pm If that is an early car on its original Sachs shocks then they may well be contributing to the low ride height. I have an '03 SE that used to sit very much like yours CHIMV8 until I recently replaced the original and VERY goosed shocks with a set of Bilstein B4s. It now sits 10-15mm higher. Do I care ? No because it handles and rides SO much better.
Mark
https://rover.ebay.com/rover/0/0/0?mpre ... 2088226770
Rears :
https://rover.ebay.com/rover/0/0/0?mpre ... 2452482771
They only have 2 sets of fronts and 1 set of rears left so be quick if you're getting some. They went so fast back in March when I got mine.
- CHIMV8
Does anybody use adjustable shocks like Gaz Gold,find it strange that the upgrades arnt?
Sterling Grey 3.0
- CHIMV8
- CHIMV8
- Sgr74
It did. My 326’s fit perfectly now and don’t rub the wheel arch on any bump while the wheels were turned.
Oh, and it drives better.
Black 2.5 Roadie.
- CHIMV8
What did you replace with,have you links u can post to them
Sterling Grey 3.0
- ben g
You will gain around 10mm in ride height after fitting new shocks. I certainly did after fitting a set of Bilstein B4's. MY Original shocks were completely dead.
- CHIMV8
Just fitted set of tyres and managed to spot this stamp
Are these after market and replaced the first set or original factory
Sterling Grey 3.0
- CHIMV8
