Repainting steering wheel trim
Any advice?
My wheel trim has seen better days and needs repainting I feel. Has anyone done this and has any advice regarding method or, primarily, paint.
Been looking at the Rust-Oleum direct to plastic options but unsure as to their durability. I want something that will last, but a Matt finish so no lacquer.
Any helpful pointers?
Aha, the only thing is I've heard plastidip doesn't last well when you're constantly in contact with it, so would wear down pretty fast on the spokes. I may well however give it a try with some acrylic satin black paint.
- Marlon
I can testify to the unsuitability of plastidip / Plastikote - as mentioned it wears and smudges due contact.
Gone: 3.0si 2008 E85
911 997 Carrera S
So paint it is, the only question is Matt or Satin finish
I painted my ones, I used etch primer and then satin black.
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
I did this recently. Halfords Matt black spray I used. 3 or 4 coats followed by Halfords Matt Lacquer. They look amazing ..
- Screenshot_20180810-192449.png (1.23 MiB) Viewed 760 times
- Sgr74
If you are removing for the first time, you will probably snap at least one of the screw bosses on the front plate of the wheel. I broke all mine but they still hold. I used a Halfords plastic primer. When I sprayed it over the original silver paint, both just wiped off to leave clean plastic. Primed and painted with mat black, looked spot on. That was over a year ago and still looks good.
By the way, you may want to look at “mewant” steering wheel covers to fit while you have your plastics off.
Black 2.5 Roadie.
Did mine a couple of weeks ago. But have ordered some soft touch rust-oleum Matt black to try and get a more OE look
- 82E3233D-D5EC-4BEA-94D8-3F7530D5A5B3.jpeg (361.37 KiB) Viewed 753 times
Now: Z4MC Titan Silver
Gone: E86 3.0Si Sport Titan Silver - M exhaust + bumper - Battery Relocated - Aero Front
E86 3.0Si Sport Silver Grey - Carbon Diffuser - Aero Kit - B/Box Mod - Storm MW V2
E85 2.5 Si Sport Titan Silver
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Cheers all for the images, I have to say these look like new trim firebobby! Any chance you could let me know what paints you used? Seems halfords paints are pretty well regarded and they do a satin black, any clear coat on top and if not, how is the paint holding up?
I need to go to my workshop to look at the make of paint, I got it off ebay if I remember rightly. There is no signs of wear on them at all.
Toyota MR2 NA 1995
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
No worries, I'm sure any decent paint will work. No lacquer coat then? I know I can get a satin lacquer spray so debating the use of it
