Paulc_bkk,paulc_bkk wrote: ↑Mon Sep 10, 2018 6:44 am A quick update
I’ve done more research and I’m starting to piece together the next steps
I found the position that the module should be located, and I’ve test fitted it. Unfortunately I don’t have any of the wiring required so I have to create my own loom for this - I’m waiting for the plug connector from my local dealer.
Anyway, there are mount points in the bulkhead, behind the airbag, above the main body control module
I lowered the main body control module and was able to mount the mirror module as shown
Hopefully these images can help someone else visualise where this goes?
I have all the parts and this has been on my to do list for a year now. The part that is holding me back is the plug connector which you refer to, that goes to the mirror module to create your own wiring. If you can tell me how you scored this plug connector from the dealer, that would be great. I believe most post 2004 cars no longer included the mirror connector for the module with the wiring harness located behind the fuse board.
