Rear brake disc opinions please
- DMC63
Car is in BMW and they've recommended putting new discs on the rear.
Heres the 'Health check' video they sent. The car wasn't jump started as the mechanic says, it was bump started.
My question is, Do you think the rear discs need changing? I'll be doing this myself if they do
https://video.citnow.com/vtXJ8S4fM0C
BMW Z4 2003 2.5i and lots of bits and pieces - 2016 - 2020 Sold
I would say so; mine were in similar shape when I bought my car a few months ago. New discs, pads and handbrake shoes; easy enough job however the hex bolt was rusted and we had to drill the head off to the shoulder then put some elbow into getting the disc off the hub. Easy job after that.
ETA worth to start budgeting for some new rear tyres too
Quite a lip, measure to be sure but worth doing.
- maxman
I did mine last year,similar to yours,handbrake shoes were ok so i did not change.
- DMC63
Thanks guys. I think I'm going to bite the bullet and do them along with the handbrake shoes.
I'm thinking of moving over to non-runflats. A rear runflat tyre cost me £275 about 18 months ago.
I'll start another thread for the tyres..
- wonkydonkey
Citing corrosion on the inner and outer edges of the discs as a reason to replace them?? Scaremongering much? Discs have a minimum thickness. If you want to charge over £100 per hour, Mr Dealership, how about you report the disc thicknesses
I replaced my rear discs and pads a couple of weeks back. £55 for all Mintex items. I've just bought Mintex discs and pads for the front end too - £55 again. Rude not to at those prices
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- DMC63
Good point on reporting disc thicknesses..wonkydonkey wrote: ↑Tue Jul 17, 2018 10:08 pm Citing corrosion on the inner and outer edges of the discs as a reason to replace them?? Scaremongering much? Discs have a minimum thickness. If you want to charge over £100 per hour, Mr Dealership, how about you report the disc thicknesses
I've always replaced parts on the car with OEM, probably down to OCD, lol. For both rear discs, pads, shoes and sensor £165 from BMW. Will get this ordered and the job done next week sometime. Rear tyre first...£OUCH£
- kis
Should be tyres. Good practice to replace in sets, particularly so if you drive more spiritedly.
Regarding discs, as mentioned they have minimum thicknesses. You've got plenty of pad left. Run to minimum disc thickness and then replace. Just like tyres, you wouldn't replace at 3/4mm when limit is 1.6mm
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- DMC63
Fair comment...What's the disc minimum thickness?kis wrote: ↑Wed Jul 18, 2018 3:04 pmShould be tyres. Good practice to replace in sets, particularly so if you drive more spiritedly.
- DMC63
I'm going to buy the kit while I have the cash and change it all when the pads have worn down.
- wonkydonkey
Minimum thickness is stamped into the disc. It should be on the external face of the handbrake bell.
Previous:
<My name is James>
<My name is James>
- DMC63
