Advice on improving the security of Z4 while parked up on a drive
- billabongmac
After the increasing reports in the news of car theft on the rise, I'm looking for some advice on things I can do to improve the security of my Z4 while its parked up on my drive?
Its not a daily drive so sits on my drive during the week and only is used at the weekends.
Does anyone still use a steering lock to slow down of put off a thief from stealing your car?
Alpina Roaster S Lux #114
Gone - Z4 2.5si SE Roadster - Intravee II & Stubby
Onlinemarkplant
Disclock, was about the best steering wheel lock you could get
- philbo909
As above, steering wheel lock.
Cars that are being stolen are usually keyless entry/start, so not as much worry with an old-school lock system like the E85.
A classic case of newer isn't always better
Sapphire black z4 coupe 135,000miles young
Take out the starter fuse? Disconnect the battery?
Buy a guard dog and chain him to the car.
I'm with discloc and disconnect battery. Unless someone tows it it's safe. Or a wheel clamp?
D
D
Z in da Head.
3.0i Z3 sport,sapphire black,3.0i Z4 roadster Sterling grey,auto,Z4 3.0si Coupe Titanium silver,Stubby &B06 Plus some other German beauties!!
Onlinemarkplant
With disconnecting the battery, you neef to remember you have to still available access the boot or the terminals in the engine bay,
- ocrx8
This. A benefit of having a key! I wouldn’t worry too much.
Current: '08 ///MR | Interlagos | Champagne | Nav | DSP | Cruise | Intravee | ZHP | Black Grilles | Stubby
Previous: '56 3.0si Sport Roadster | Ruby Black | Extended Champagne | Nav | DSP | Xenons | 108s | Non-RFs | Stubby
- Silverzedtom
1+ for a steering lock. You could also look into fittings hidden switch.
E85 2.5si
F55 Cooper S
F55 Cooper S
You might want to watch https://www.youtube.com/watch?v=goJ9nsrt6Sw before choosing a steering wheel lock!
Start the day with a smile, get it over with.
Bog standard 2007 3.0si manual E86 in Montego blue with black leather, currently fitted with MV2s
- MrPT
I have a disklok, which is great but you do need to be very careful when you put it on so that it doesn't indent the leather or break the plastic trim on the lower steering wheel spoke.
2006 Z4 2.5si: gone
2006 Z4 2.5si: gone
+1 for wheel lock and an isolation switch on the battery. I had one on my E85. Very easy to use and convenient. Plus it helps to stop any drain on the battery whilst car is standing. The only downside I found is that the clock stopped working when the battery was isolated . So if you want a clock you have to re-set it each time you have used the battery isolation switch.
- Crazy Harry
Inset a post on the drive to prevent it being moved - like they do at car dealerships
I bought the Milenco high security steering wheel lock after reading about the vulnerability of keyless entry systems (which is fitted to my Zed) and am impressed with the design and engineering of the device. It’s easy to fit and on tests massively exceeded the Thatcham standard for these type of security locks.
http://www.milenco.com/products/securit ... wheel-lock
- patriot66
I can recommend this isolator switch
https://www.autoelectricsupplies.co.uk/ ... ategory/30
- Jembo
Agreed, ones which simply slot into the s/wheel are defeated by a hacksaw on the steering wheel itself.
Out of interest, that’s not my old Maldives I can see through the window?
Lifer 54
Lifer 54
