Essex
Removing Whippy For Stubby
Mini R56 FJCW
Z4MC Imola Red
Z4MC Imola Red
- kis
Ahh bit far then. I might have been able to pick one up.
Not sure what you need exactly, but if you get something like this then you should have everything you need.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Any guide as to how i can access from the inside, i can get my hand behind the inner lining but no idea how to undo it.
Mini R56 FJCW
Z4MC Imola Red
Z4MC Imola Red
- kis
No idea either I'm afraid. I'll take a look this weekend if that's any use to you... unless someone else chimes in that's done it before.
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- philbo909
Not done it on the Coupe which has a load more plastic covering everything in the boot.
Once you get behind the plastic it's just one torx screw holding the Base to the car
You'll need to buy a new antenna Base now though
Sapphire black z4 coupe 135,000miles young
- RustyZ4
Well I definitely call that a stubby,,,,
Must have been well locked in to snap like that, you can get a bolt extraction set from screwfix, where you drill a small hole in the bolt and thread in the removal tool
Z4 E85 3.0, gone but now with son
Spray thr hell out of it now with penetrating oil. Same in morning and then get a good mole grips on it. It should come out. There seems to be just enough left to grab hold off.
Worth a shot.
D
Z in da Head.
3.0i Z3 sport,sapphire black,3.0i Z4 roadster Sterling grey,auto,Z4 3.0si Coupe Titanium silver,Stubby &B06 Plus some other German beauties!!
- RickRob
May the power of the whippy remain!
///M Roadster. 2007 Black/Black. Rear spoiler, whippy aerial, mud flaps and gimp-style wind deflector!
That will teach you for vandalising your Zed you now have a stumpy
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
Stumpy is the new look, rugged and abit pissed
Mini R56 FJCW
Z4MC Imola Red
Z4MC Imola Red
- kis
You're right, were definitely related!Z4 COUPSTER wrote: ↑Fri Jul 13, 2018 8:01 pm Spray thr hell out of it now with penetrating oil. Same in morning and then get a good mole grips on it. It should come out. There seems to be just enough left to grab hold off.
Worth a shot.
D
That's what I had to do on another car. Key is the oil. And don't rush, put some on in one day (morning, evening, etc), again the next morning and then give it a go in the afternoon. I also used a hammer to tap the screw section to try crack the seal. You're not hammering a dowel in or anything, just a light tap to try free it up. The one I had did protrude further but like above, you still may be able to get it off...
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- RustyZ4
You could now go down the Araldite/Coat Hanger route, be better reception than a stubby
- philbo909
And you can dry your shirt on the way to work
