BC coil over fitting
9designs
Post by 9designs » Wed Jul 11, 2018 11:59 pm
Anyone fitted a set of BC Racing coil overs, mine arrived this week, any tips on set up or do’s or don’ts when fitting?
56 Plate 3.0 SI Manual - Black with Red Leather- Scorpion exhaust, BC coil overs
54 Plate 3.0 SE Auto - Silver with Red Leather. SOLD
Scooba_Steve
Post by Scooba_Steve » Thu Jul 12, 2018 6:36 pm
Just use TIS. New bottom bolts and Loctite. Might as well get all new mounts etc.
9designs
Post by 9designs » Fri Jul 13, 2018 8:28 pm
Do I have to sign up for that access? Never seen it before :oops:
Scooba_Steve
Post by Scooba_Steve » Sat Jul 14, 2018 9:28 am
Free online, search for TIS - it's the workshop manual.
Work out what the coilovers come with then buy new for the other bits. Doesn't look like front top mounts are needed, but rear possibly.
9designs
Post by 9designs » Sat Jul 14, 2018 3:56 pm
Seems I have everything except new front lower knuckle bolts :x Which are supposed to used only once?
Any idea what the part number is ?
Rear is done, just need to set height.
Scooba_Steve
Post by Scooba_Steve » Sat Jul 14, 2018 8:49 pm
RealOEM will give you part numbers specific to your car, same as the dealers use, just pop in your VIN.
https://www.realoem.com/
