Tyre pressure SOS
Tyre pressure SOS
HI Forum, I bought my Zed 3 months ago and its starting to feel a bit bouncy - i think i need some air in my tyres but not sure what pressure i should be looking for. Can't seem to find my wheels online for the Zed and want to be safe rather than sorry. Any advice/help much appreciated.
Its a 2004 E85 with 19" 225/35ZR19 tyres. For 18" the web seems to suggest 33PSI up front and 36PSI for the rear. Does that sound about right?
Thanks again....
Thanks again....
06 E85 Titanium Silver 2.5si
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
Tyre pressure SOS
Have you looked at the standard tyre pressures on the driver’s door jamb?
- kis
Tyre pressure SOS
Sounds about right. Use that as a starting point for your 19's. You can always add/reduce slightly as required. So long as it's not really low (20's) or high (40's) you're probably okay
Also worth noting that Z4's didn't come with 19's as standard... that's probably why you're not finding pressures.
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Tyre pressure SOS
Thank you - will pop to a garage later and check my air levels
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
- kis
Tyre pressure SOS
I use Sainsbury, air and water is free
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- ben g
Tyre pressure SOS
Only use them if you don't mind waiting 30 minutes for all the other cheapskates to use it first everytime I drive past my local sainsburys garage, it's full of cars queuing for it.
- kis
Tyre pressure SOS
I normally go first thing (stupid o'clock in the morning so no queue) as I've got one on the way to work so I drive very sedate till I've checked the air. As the tyre pressures should be done from cold. Then I drive... normally lol
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Tyre pressure SOS
We must be related, that's my normal, manoeuvre.
D
Z in da Head.
3.0i Z3 sport,sapphire black,3.0i Z4 roadster Sterling grey,auto,Z4 3.0si Coupe Titanium silver,Stubby &B06 Plus some other German beauties!!
- patriot66
Tyre pressure SOS
You've been driving your Zed for 3 months and never checked the tyre pressures ?ROBOTCOWBELL wrote: ↑Wed Jul 11, 2018 10:19 am HI Forum, I bought my Zed 3 months ago and its starting to feel a bit bouncy - i think i need some air in my tyres but not sure what pressure i should be looking for. Can't seem to find my wheels online for the Zed and want to be safe rather than sorry. Any advice/help much appreciated.
Thanks again....
Tyre pressure SOS
Tyre pressure was fine, it just started to feel a bit soft, popped to a garage and air pressure was as above, I must just have got used to the feel of the drivepatriot66 wrote: ↑Fri Jul 13, 2018 8:40 pmYou've been driving your Zed for 3 months and never checked the tyre pressures ?ROBOTCOWBELL wrote: ↑Wed Jul 11, 2018 10:19 am HI Forum, I bought my Zed 3 months ago and its starting to feel a bit bouncy - i think i need some air in my tyres but not sure what pressure i should be looking for. Can't seem to find my wheels online for the Zed and want to be safe rather than sorry. Any advice/help much appreciated.
Thanks again....
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
- patriot66
Tyre pressure SOS
You should get into a weekly routine of checking the engine oil, coolant, brake fluid levels AND tyre pressures. Safety first !ROBOTCOWBELL wrote: ↑Sat Jul 14, 2018 2:29 pmTyre pressure was fine, it just started to feel a bit soft, popped to a garage and air pressure was as above, I must just have got used to the feel of the drivepatriot66 wrote: ↑Fri Jul 13, 2018 8:40 pmYou've been driving your Zed for 3 months and never checked the tyre pressures ?ROBOTCOWBELL wrote: ↑Wed Jul 11, 2018 10:19 am HI Forum, I bought my Zed 3 months ago and its starting to feel a bit bouncy - i think i need some air in my tyres but not sure what pressure i should be looking for. Can't seem to find my wheels online for the Zed and want to be safe rather than sorry. Any advice/help much appreciated.
Thanks again....
Tyre pressure SOS
Thanks for that advice and will do that alongside my new weekly routine of shampoo and polishpatriot66 wrote: ↑Sat Jul 14, 2018 7:11 pmYou should get into a weekly routine of checking the engine oil, coolant, brake fluid levels AND tyre pressures. Safety first !ROBOTCOWBELL wrote: ↑Sat Jul 14, 2018 2:29 pmTyre pressure was fine, it just started to feel a bit soft, popped to a garage and air pressure was as above, I must just have got used to the feel of the drive
Top down
Grin on face
Will always wave
Top down
Grin on face
Will always wave
