Don't think so, as I was under the impression that the SC and PAS pump couldn't co-exist, according to the (lack of) info I could find, that pic shows that they can on an M54..
Mike
Arguably none, after all the only high pressure line is the feed from the pump to the rack.Monkeydonkeyratmagic wrote: ↑Thu Jul 05, 2018 8:41 am It can be done. I have nearly all the kit. The tank can't go in the usual spot and thus needs longer piping. I'm no hydraulic engineer and have no idea on the impact it'll have, esp if they are wider.
Fair enough. May try one from a 530i it's on the side it needs to go on these and in theory the pump will be the same.mjennings23 wrote: ↑Thu Jul 05, 2018 10:57 amArguably none, after all the only high pressure line is the feed from the pump to the rack.Monkeydonkeyratmagic wrote: ↑Thu Jul 05, 2018 8:41 am It can be done. I have nearly all the kit. The tank can't go in the usual spot and thus needs longer piping. I'm no hydraulic engineer and have no idea on the impact it'll have, esp if they are wider.
For what it's worth I'm led to believe they are 16mm ID anyway, but I'm sure Mike can check that easily and get some replacement ordered up.
