Which mod for a bit more growl and a bit more grunt?
Hi guys,
I’ve had my 3.0si coupe for about 6 months now and have done quite a few things to it: Bilsteins all round, new wishbones, new bushes in important places, new fluids, CDV delete, wheel alignment and a bunch of other things. Now I’m thinking it would be nice to get a bit more audible snarl out of the exhaust (nothing silly, but something I can actually hear, unlike now), and a bit more power (not much, but something I can feel). Is there a simple and not too expensive mod, or mods, that would do this? Recommendations please!
- DPG
Sound Generator mod (foam removal)
Bypass pipes
GruppeM
New Exhaust
Remap for power but you probably wont see great gains.
Bypass pipes
GruppeM
New Exhaust
- dunks
DLV backbox mod.
A bit more power might be a struggle on the 3.0si unless you go down the supercharger route to be honest... but that said depending on mileage/condition of engine a good service or a few part replacements may help, vanos solenoids or vanos unit in particular. There's a few people on here that have benefited from an overhaul of the vanos system. not something i've done myself but now i'm on 97k I'm considering a refresh to see if it has any impact.
I've had extensive exhaust work done on my coupe and it's insanely loud... actually it's too loud but it's a lot of fun!!
I've had the front silencer removed and replaced with a Y-Pipe and a running a very small free flowing back box, it gurggles, pops and bangs and sounds incredible at high revs.... i originally had a much quieter back box with this Y-Pipe system but wasn't happy so got this smaller one made up, the car was so much more responsive after fitting the free flowing box and revs quicker than it did previously! That could just be due to the first box being too restrictive though!
There's also the DLV exhaust mod that a lot of people have... I've heard this in the flesh and it's way nicer than standard and a lot cheaper than a full system so may be worth considering as it's not over the top, certainly a nicer note than stock with the added bonus of pops and bangs. If you do a search on the forum you'll probably find a link or 2 to videos of the modded back box.
I did the sound generator mod and although it does increase noise i didn't like it, was a bit too much and sounded artificial (just my opinion) so have put them back in... there's 2 foams in there so you can play around and try to get a bit more noise and see if it suits you. Outside of that there's induction kits, off the shelf for the 3.0si engine is a bit limited and very expensive, the AFE kit is around £600 new but gives the engine a nice growl.
The other thing you could try for a bit more performance is an LSD, expensive and won't increase power but will help you get the power down better.
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
- philbo909
As above, drop Mike a pm, his boxes give a bit more of a meaty sound, crackle and pops. Leave the sound generator as it is, it's not a nice sound when both are out, too boomy in the Coupe imo
Sapphire black z4 coupe 135,000miles young
Thanks, guys! I’ve been reading around about DLV and listening to some videos, and looks like just the sort of thing I would want. Only issue is I am in Finland, so exchanging old back box not so easy. I’ll ping and ask if there’s any possibilities.
Yes, had a go with this last weekend and I agree. Removed both inserts and it sounds kinda odd, though not so bad if you have windows open and it mixes with exhaust note. I will go to one foam plug and see what that’s like, but it is not really any kind of substitute for actual exhaust tones.
Road trip?ionofchios wrote: ↑Fri Jun 15, 2018 3:03 pm Thanks, guys! I’ve been reading around about DLV and listening to some videos, and looks like just the sort of thing I would want. Only issue is I am in Finland, so exchanging old back box not so easy. I’ll ping and ask if there’s any possibilities.
- philbo909
Might be worth checking this thread op viewtopic.php?t=25214
A proper exhaust upgrade is cheaper than the postage/fuel
- Yorkie Z
Just get your local exhaust shop to do the job, it's very simple. I'm sure DLV will share what's needed.ionofchios wrote: ↑Fri Jun 15, 2018 3:03 pm Thanks, guys! I’ve been reading around about DLV and listening to some videos, and looks like just the sort of thing I would want. Only issue is I am in Finland, so exchanging old back box not so easy. I’ll ping and ask if there’s any possibilities.
A Dirty M///
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- wonkydonkey
What does Mr ducklakeview charge for these backboxes of his? I imagine the cost of posting a backbox up to him to do an exchange is about as much as the saving you'd make for the exchange.
Previous:
~2006 Z4MR in Silver Grey
~2003 3.0i E85 in Sterling Grey
Click here for the Sticky Steering thread
<My name is James>
<My name is James>
- Mr Tidy
James, as you are in Somerset MachineMonkey in Oxfordshire might be a better option for you.
I'm pretty sure I've read about him doing a similar job, but he does it on your car IIRC rather than an exchange service.
But it would just give you an excuse for a decent drive in your Z4!
Or you could just send them both a pm and go from there.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- wonkydonkey
Thanks Mr Tidy, good to know there are forum-based options
Previous:
<My name is James>
<My name is James>
- Tcochrane92
You need to clean your car, it's filthy!!Chris1981 wrote: ↑Fri Jun 15, 2018 9:03 am A bit more power might be a struggle on the 3.0si unless you go down the supercharger route to be honest... but that said depending on mileage/condition of engine a good service or a few part replacements may help, vanos solenoids or vanos unit in particular. There's a few people on here that have benefited from an overhaul of the vanos system. not something i've done myself but now i'm on 97k I'm considering a refresh to see if it has any impact.
Current: Imola Red 400bhp 640d & Ocean Blue BMW S1000XR Sport SE
Past: Silver Grey Z4MR, Silver Grey Z4C & Titan Silver Z4 3.0i
