Brake pipe replacement
I was aware of an outstanding advisory for corrosion of brake pipes when I recently bought my Zed. So I thinking about getting it booked in soon to be sorted. The advisory states “both front to rear and both to rear calliper brake pipes corroded at parts”.
Is this a sizeable task with tank drop? I’m not really thinking of tackling it myself, but just preparing for what sort of bill I might expect from a local indy.
I’ll probably get a couple of other bits sorted while it’s in. I suspect the drive shaft donut needs doing for one and a general check over for peace of mind.
- bmwaddict
It's quite a big job, I just had it done on mine, propshaft down, and I think subframe too. About 5 hours labour I think I was charged.
Currently zedless
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
Previous:
'07 Ruby Black Z4MC
Thanks. Going to be fair size bill then. Will get estimates from a couple of nearby indys.
Has anyone here tackled this themselves, at home on the driveway? I’m imagining not if it requires tank, and/or subframe and/or driveshaft drop.
I might be wrong, but I'm sure it's possible with the tank and subframe in situ. The lines run round the tank rather than over.
- Mr Tidy
Shame you are located where you are OP.
I had rear brake pipe advisories for corrosion twice on my Z4 so when I was up in Cheshire last year I got them both replaced in copper by ducklakeview for a very reasonable price (and a spare key while I was at it). The pipes both run inside a cover under the floor beneath the passenger seat, then separate a bit behind the seat to each side.
The offside one does seem to cross the car in front of the fuel tank, and I think the problem is that the way an OEM pipe for the offside is shaped means you can't wiggle it through the gap, whereas with copper you can! My BMW Indy was definitely talking about needing to drop the tank when I asked him about it.
For what I paid it might even be worth thinking about a short trip North - I'd definitely recommend getting a price from Mike before you make a final decision.
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
Easy job. I've done loads. Need a 2 post lift to do it with ease and a good flaring tool to join to steel pipes.
3 hours or less. Don't need INPA or any other scan tool to bleed the system out either.
I charge about £150. Pipes and fluid included.
Andy.
Andy.
I’ll get some quotes locally, but if that’s your price Andy it may be worth me making a trip up to see you.andyfanshawe wrote: ↑Sat May 26, 2018 9:48 pm Easy job. I've done loads. Need a 2 post lift to do it with ease and a good flaring tool to join to steel pipes.
Andy.
Had mine done by DLV in copper which was a wise decision as steel will corrode again Cooper will not so total peace of mind and also a long ownership decision
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
- Ducklakeview
Drop the tank? Pfft..
Do these in my sleep, replacing with Kunifer (copper alloy) that doesn't corrode. Couple of hours work, £150 including materials.
Mike
Mike
- bmwaddict
That's a great service at great value Mike! Wish I was closer to you I would have asked for your services
Currently zedless
Previous:
'07 Ruby Black Z4MC
Previous:
'07 Ruby Black Z4MC
- tug
Hi Andy, i desperately need mine doing i live in loughborough so not that far. Could you please let me know if you could help me out with this, but i can only do weekends because of work commitments thanks.andyfanshawe wrote: ↑Sat May 26, 2018 9:48 pm Easy job. I've done loads. Need a 2 post lift to do it with ease and a good flaring tool to join to steel pipes.
Andy.
Cheers, tug
E85 N46 2.0i SE BLACK SAPPHIRE
Good to know Mike. That’s two of you circa 200 miles / 3.5 hours away, but could very well be worth making the trip.Ducklakeview wrote: ↑Sat May 26, 2018 11:24 pm Drop the tank? Pfft..
Mike
By the way, my car has your ‘tweaked’ OEM back box. Love the noise it makes!
- Ducklakeview
Glad you like it,ErrErrminator wrote: ↑Sun May 27, 2018 8:00 amGood to know Mike. That’s two of you circa 200 miles / 3.5 hours away, but could very well be worth making the trip.Ducklakeview wrote: ↑Sat May 26, 2018 11:24 pm Drop the tank? Pfft..
Mike
Mike
- TomK
Mike, have you done this on an m z4? I was also told it's a fairly big job, tank down etc because of the diff?
If not I may take a trip north to you back via Anglesey for this
Hmmm, nasty. Think these were on the verge of failure! Definitely the right time to get them replaced.
