indicator click
bluespit
indicator click
Post by bluespit » Fri May 18, 2018 7:43 pm
interesting one this, the click click sound made by the indicators is now working intermittently. Indicators are working fine.
anyone any ideas why before I go delving not the dashboard?
is it actually a relay (sound like it from behind the dash) or does it come through the speakers?
now I'm about to have more time I've suddenly got less toys to play with!
obewan
indicator click
Post by obewan » Fri May 18, 2018 7:51 pm
Pretty sure it's the relay - definitely not the speakers
Maybe the first signs of impending failure
Sometimes the relay is mounted in the fusebox
E89 2.0 SDrive MSport
Honda CB500F.
Gone but not forgotten E85 2.0 MSport
bluespit
indicator click
Post by bluespit » Fri May 18, 2018 9:17 pm
hmmm, can't find a relay listed anywhere or a wiring diagram with a relay
very odd...
Silverzedtom
indicator click
Post by Silverzedtom » Fri May 18, 2018 9:36 pm
Was the bulb on the cluster lighting up?
E85 2.5si
F55 Cooper S
bluespit
indicator click
Post by bluespit » Fri May 18, 2018 10:11 pm
yes - both sides flash in time with the outside lights
GAZA62
indicator click
Post by GAZA62 » Sat May 19, 2018 9:39 am
Bad news on this one I have the same problem and its a new speedo not cheap around £1300 fitted and programmed.
Someone on here did mention it can be fixed without replacement which would be a lot better option but for now I live with it as I cannot here it with the roof down or music playing
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
bluespit
indicator click
Post by bluespit » Sat May 19, 2018 12:19 pm
Battery disconnect for 15 mins and all OK again!
For how long I wonder
