De-Limit Top Speed on Z4C
- R60BBA
Okay so as previously posted I will be going on a roadtrip to Germany next month and I am quite interested in seeing what kind of speeds these things can get up to.
Ofc the car is limited to 155mph but I’ve heard that the N52B30 engine can get up to 170mph in a Z4.
Which brings me onto my questions:
Can you de-limit the car and keep stock map settings? If so, what is the cost?
I’ll be on the Autobahn for a period of time and so would like to test this out as I’ve already done 155 *cough* that was a lie #M40
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- buzyg
The Z4M will do 170+ in 5th no speed limiter on 5th as far as I can tell. It runs into the rev limiter at about 172. No idea what the 3.0 will do, I would hazard a guess at around 160. But I don't know the gearing.
- Smartbear
Hi, it should be possible as I’ve had the 155mph limiter removed from my 2litre. I’ve never got to the local chip shop so fast!
e85 3.0si sold
- R60BBA
How much did that set you back buddy!
- hopz121
I am not sure that it will go much past the 155 to be honest so pretty pointless paying a lot of cash in removing the limiter IMO
Its not like 155 MPH is exactly slow
Also I wouldn't be overly keen to keep the car at 155 for a prolonged period of time.
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
- hopz121
To add to the above, if you wanted to get it done still you could try and contact some people who code BMW's as it may well be an option on the software. (it was on my M3 anyway)
Good luck
Good luck
like Buzyg I was under the impression speed limiter was only effective on 6th gear, this was also the case on my old e46 M3... potentially that's an S54 thing though!?
What gear were you in when not doing 155 on the M40?
E86 Coupe 3.0si Sport - Montego Blue, Pearl Grey with Piano Black dash
BC BR series Coilovers, powerflex bushes, 15mm spacers, Custom SS exhaust, CDV delete
- Beedub
mine has been de-limitered.
- ph001
Porsche never limit their cars AFAIK and the closest in terms of power is the 986 Boxster S with 258bhp. That tops out at 164mph so I would expect something very similar from a 3.0Si.
- abar121
My N52 engined 330i manual would easily hit is speed limited at an indicated 163mph, real 154mph. Quite impressive for a cooking 3 series.
I could believe it would do a real 160mph, possibly a couple mph more, but it's going to need more power to hit a real 170mph.
'07 Z4M Interlagos Blue. All options except extended leather.
- buzyg
Did you ever take her to VMax?
Mine starts to go light at the front above 160.
I'guessing yours could get very interesting at 185 or so.
- skelters
It is a Coo Pee though so maybe 168mph and that'll be it due to the extra weight with the tin lid, mahoosive hatchback and the rear window!
Might be worth getting a Roadster in front of you as a pacemaker but then you'd have issues trying to keep up!
2007 Z4 3.0si Sport. Silver Grey Metallic, Brembo Brakes, HEL Braided Brake Hoses, Machine Monkey Exhaust Tips, Stubby, Piano Black trim, Black Leather, Bilstein B12-Pro-Kit, Michelin Pilot Sport 4 on MV2's. Roof Motor in the Boot!
- bradz
The 155 mph limiter only comes into effect in 6th.... you'll struggle to hit it.
My Si coupe really struggled at 150 (in 5th). doubt you will see 160 so probably not worth it tbh!
My M pulls to 172 and hits the rev limiter in 5th
Z4M Coupe, E92 M3, E46 M3 Track car
- Mr Tidy
In that case I wonder why Wiki quotes a 3.0Si E85 as being 1,400 kg, and a 3.0Si E86 as being 1,395 kg? Must be all the metal welded in to make the Roadster less floppy!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- Mr Tidy
It sounds like maybe the 3.0Si is too low-geared in 5th and too high-geared in 6th for optimum top end!
Seeing as BMW were going to fit a limiter I can see why they might have done that.
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
