Changing handbrake shoe springs
Jamo96
Post by Jamo96 » Wed Mar 21, 2018 5:35 pm
Am currently changing my handbrake shoe springs, finally got the whole assembly back together, pull the handbrake and nothing, I was just wondering (probably a very newbie question) wether or not you have to have the handbrake on or off when changing over the shoes as with it on a can’t get the little hook over the cable bit with it off, it seems to have not done anything atall?? Any help very much appreciate
2003 2.5i Sterling grey E85 manual, black leather interior,
ph001
Post by ph001 » Wed Mar 21, 2018 5:49 pm
You would do it with the handbrake off. Have you got the little adjuster thing set correctly (no.3 below)? There is also a bigger adjuster on the handbrake level (you have to remove the gaiter to see it).
With the handbrake off, turn the adjuster until the disc just binds then back it off a couple of notches. Getting those springs on and off is a lot of fun isn't it!!!
handbrake adjuster.jpg (7.88 KiB) Viewed 490 times
rally-chris
Post by rally-chris » Wed Mar 21, 2018 5:53 pm
As above, I suspect you haven't readjusted the brake shoe position after refitting the brake disc. It's a bit of a fiddle working through one of the wheel bolt holes, but you have to wind the wheel around in the correct direction until the disc locks, and then back it off a certain number of 'clicks'. If you've refitted the same shoes as before then I doubt you'd need to adjust the cables to the handbrake lever.
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
ph001
Post by ph001 » Wed Mar 21, 2018 6:01 pm
...it might also be worth taking the disc off again and checking whether the mechanism (no.2 on the picture) is moving freely and pushing the bottom of the shoes out with somebody else sat in the car pulling the handbrake on and off.
I'm just wondering if the Z has a spring loaded tensioner on the handbrake cable like on some of 3 series.... https://www.1addicts.com/forums/showthread.php?t=655621
Jamo96
Post by Jamo96 » Wed Mar 21, 2018 7:21 pm
ph001 wrote: Wed Mar 21, 2018 5:49 pm You would do it with the handbrake off. Have you got the little adjuster thing set correctly (no.3 below)? There is also a bigger adjuster on the handbrake level (you have to remove the gaiter to see it).
The springs were the absolute worst, okay cheers, done it with the handbrake off and I’ve adjusted the little adjuster in the wheel to push the pads out so they are biting, I haven’t touched the adjuster under the handbrake gaitor though so maybe this is the issue?
Ewazix
Post by Ewazix » Wed Mar 21, 2018 7:26 pm
You are not alone, reassembling the set and getting the springs back is a PIG. It's the one job you won't find an amateur youtube video for! :|
2018 Cooper S Countryman
Fiesta Ecoboost
MJJamieson
Post by MJJamieson » Wed Mar 21, 2018 7:46 pm
34 10 014 Adjusting handbrake.jpg (217.34 KiB) Viewed 449 times
34 10 014 Adjusting handbrake2.jpg (75.94 KiB) Viewed 448 times
2004 E85 Z4 2.5i SE Sterling Grey.
