Centre Console Refurbishment
Hi all, the centre console handbrake plastic area on my E85 2.0i SE is worn. I will probably end up taking the whole console out and replacing the damaged parts if I can find from a breakers yard etc. I know it's a time consuming and tricky job and was wondering if anyone else has had the same problem and come up with a quick fix? I've asked a local supplier to see if they could do some sort of wrap in situ etc. Any thoughts would be highly appreciated, Best Wishes, Elsa
- ben g
Remove the centre console, unscrew the bits, sand them back and respray them. I done mine years back, as mine were pre-facelift grey and I wanted them black.
Hi Elsa, Where are you based?Elsavavavoom wrote: ↑Tue Mar 20, 2018 3:22 pm Hi all, the centre console handbrake plastic area on my E85 2.0i SE is worn. I will probably end up taking the whole console out and replacing the damaged parts if I can find from a breakers yard etc. I know it's a time consuming and tricky job and was wondering if anyone else has had the same problem and come up with a quick fix? I've asked a local supplier to see if they could do some sort of wrap in situ etc. Any thoughts would be highly appreciated, Best Wishes, Elsa centreconsole.jpg
Thanks Ben, I've taken the gear stick surround out and the centre console plate, I can now see the original parts have been sprayed with a matt black laques which has bubbled, I'm in two minds what to do now: either prep and spray the two removed bits and spray the rest of the housing in situ, or carbon wrap the shift surround and prep the plate and side panels and try an alcantara wrap......decisions, Best wishes, Elsa
Theses are the two pieces removed
- image2.jpeg (157.2 KiB) Viewed 712 times
- image1.jpeg (207.57 KiB) Viewed 712 times
Hi Sinthedup, I am based in Chester, Best wishes, Elsa
Oh my ...... look at that, sh*t that would drive me mad, as my car OCD would freak me out looking at that.
i think the whole interior out and hoover dust polish and repair or replace and back to normality.
sal
sal
PROUD OWNER OF .......
BMW Z4 MSPORT:
LANDROVER DISCOVERY OVERFINCH:
BMW Z4 MSPORT:
Do those two bits just pop out?
Hi Kamuela, indeed they do. First tease out the gaiter around the gearstick, this then gives you access to gently pull out the plastic gearstick surround which can then be removed by feeding over the gaiter so you dont have to take the gear knob off. This then allows the centre rectangular shape section to be pulled towards the gearstick and removed
Has someone spilled some acid or something on that plastic - never seen anything like that before! I would try and get it nice and even and spray it. Problem with that is, once you start putting things right, where do you stop...before you know it you'll have done your whole interior.
i bet whats happened is that that is the collection point for air fresheners............
sal
sal
BMW Z4 MSPORT:
BMW Z4 MSPORT:
- ben g
Yep. The liquid air fresheners, specifically. The stuff inside eats away at any painted trim. Same thing happened to my missus' Fiesta.
- Mark-Z4
As said above, looks like acidic burn from air freshener.
Plastikote is pretty good paint and you can get satin black.
E86 - Space Grey | Grey Oregon Pearl Leather | Sport Interior | ///M Bumper | Aero Skirts | Piano Black Trim | ///M Wheel | Eibach Pro | CSL | HID | LED | ZHP | MM Tips | Stubby SOLD
Hi Guys, decided to go with the Alcantara wrap option, cost less than a fiver for the materials and half an hour to make up a template, thanks for all the recommendations, Best Regards, Elsa
That's not half bad!
(and no, it's not all bad either before someone pipes up!!)
