Panic time?!
Panic time?!
Hi all
I decided to act on impulse the other night and brought some brand new alloys.
I currently have on some near perfect 108’s and my new alloys are 18” staggered 8” front and 9” rears. These are going to be on ET30’s.
Are these going to still be ok? I can’t work out which way ET’s go ie greater number=further out?
Have I malfunctioned??
JJ
JJ
Rarely used 3.0si Coupe!
- ben g
Panic time?!
The lower the number, the further out they will sit.
- rossonr
Panic time?!
108s are
Front Wheels: 8Jx18 ET47 (p/n BMW 36116758194)
Rear Wheels: 8.5Jx18 ET50 (p/n BMW 36116758195)
- Mr Tidy
Panic time?!
Hopefully forum wheel guru Mr Wilks will be along soon to help you out!
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- MACK
Panic time?!
I think you may have pushed this a tad too far. I've seen folks on here get away with upto 15mm front and 25mm rear spacers but I think you looking at the equivalent of 17mm front and 27mm rear. I'm no expert though you may well get away with it, particularly if your not lowered etc.
A good site for checking this sort of thing is "will they fit"
Silver 05 3.0i SE
White E89 20i M Sport
Panic time?!
Thanks Mack
I’ve had a look and I think it works out as
17mm wider on fronts
20mm wider on rears
It’s going to be tight I think!
These sizes are on 18” alloys
20mm wider on rears
- mr wilks
Panic time?!
Currently have 19inch style 326 on my E86 , those are 8j et 29 front & on full lock get a slight rub only on drivers side (on stock MSport suspension )
rears are 9j et 40 & fit fine
Your new set would sit 10mm further out on rear & the same on front , just be wary of tyre size for front , maybe a 215 40 would be best ?
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
current Bmw 6 Gran Turismo
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
Panic time?!
Thanks mr wilks!
The front tyres are 225/40
The rears are 255/35
YOKOHAMA ADVAN NEOVA AD08R
I also have lowering springs to go on too
- mr wilks
Panic time?!
Apply vaseline liberally you will have chaffingJohnnyz4coupe wrote: ↑Mon Mar 19, 2018 8:12 am
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- Buckz
Panic time?!
Should've asked before ordering really.. you'll have rubbing on the front for sure.
Panic time?!
Got loads in the missus top draw!
Will it be rubbing on the inside fronts?
- mr wilks
Panic time?!
The outer edge of front tyres will catch the arch liner near the access panel for headlight bulbs . Poor design really as it's a flat area of a arched liner .Johnnyz4coupe wrote: ↑Mon Mar 19, 2018 8:45 am Got loads in the missus top draw!
Running part worn tyres 4-5mm as opposed to brand new can be a advantage as can different tyre brand.
Hankook + Falkens seem to be narrow fitting , Michelin + Pirellis are much fuller by comparison
3 ZMRs
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
3 E89s
5 Si coupes
5 Si roadsters
997 C4
TTRS
F82 M4
MK7 Golf Gti
- MACK
Panic time?!
Johnnyz4coupe wrote: ↑Mon Mar 19, 2018 7:48 am Thanks Mack
20mm wider on rears
I think you've not taken into account your new rears are half an inch wider at 9". The 108s are only 8.5" hence why I'm getting 26.4 and your getting 20. Especially now you've said your lowering it your going to have a few issues. Is it too late to change your order?Johnnyz4coupe wrote: ↑Mon Mar 19, 2018 7:48 am Thanks Mack
20mm wider on rears
Silver 05 3.0i SE
