Anyone have any photos of the steering wheel eccentric ring in situ?
- Sky-drive
Does anyone have any photos or images of the eccentric ring located between the steering column and steering column electric motor? I would like to have a go at adjusting mine and some imagery would certainly help.
Xenons | LED S/lights | CF Trim | Royale SW | ZHP | CDV | AUX | DISA | Vanos Refurb | Cruise | MV2s | Roof motor > boot | K&N | Sound Gen | Interior LEDs | E/H seats | Remapped
- Darkangelv2
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
- Ducklakeview
Just use an 8mm flex headed ratchet spanner. Makes access easy and turns it into a 10 min job.
Mike
Mike
Yeah most people don't have an 8mm flex headed ratchet spanner buddy. OP don't listen to this snob.Ducklakeview wrote: ↑Fri Mar 16, 2018 10:41 am Just use an 8mm flex headed ratchet spanner. Makes access easy and turns it into a 10 min job.
Mike
Just use a plain old 8mm wrench and try to wiggle it in there.
- Grumpyowl
- Crazy Harry
What a strange way to introduce yourself - why not post some pics of your Zed or a bit about yourself if you're visiting or looking for a Zed. Plenty of helpful advice on here learnt by bitter experience in most cases and shared to make other forum members lives easier.z4rumble wrote: ↑Sun Mar 18, 2018 4:03 pmYeah most people don't have an 8mm flex headed ratchet spanner buddy. OP don't listen to this snob.Ducklakeview wrote: ↑Fri Mar 16, 2018 10:41 am Just use an 8mm flex headed ratchet spanner. Makes access easy and turns it into a 10 min job.
Mike
- ben g
It's quite obvious that user isn't a newbie
- Crazy Harry
I wonder who...............the short list is short!!
///M|Silver Grey|Black Leather|BT|Nav|DSP|Heated Seats|PDC|Stubby|Turner Limiters|Turner Rear Top Mounts|Bilstein B12|Powerflex ARB Bushes|Powerflex Lollipops|M-Track|
SOLD
SOLD
- Ducklakeview
Charming.z4rumble wrote: ↑Sun Mar 18, 2018 4:03 pmYeah most people don't have an 8mm flex headed ratchet spanner buddy. OP don't listen to this snob.Ducklakeview wrote: ↑Fri Mar 16, 2018 10:41 am Just use an 8mm flex headed ratchet spanner. Makes access easy and turns it into a 10 min job.
Mike
FYI, if you don't use a ratchet headed spanner, you won't be able to swing it enough to get the spanner on the next set of flats.
Mike
how rude are you would not be expecting any help on here with comments like that sure DLV was only trying to help suggest you climb back in your box ( Marius)z4rumble wrote: ↑Sun Mar 18, 2018 4:03 pmYeah most people don't have an 8mm flex headed ratchet spanner buddy. OP don't listen to this snob.Ducklakeview wrote: ↑Fri Mar 16, 2018 10:41 am Just use an 8mm flex headed ratchet spanner. Makes access easy and turns it into a 10 min job.
Mike
2004 z4 30i auto Toledo blue stubby Areo front back sideskirts and rear spoiler M/// MFSW DLV exhaust mod mma tips vanos overhaul 108s refurbed ram air scoop E46 M3 heated seats clear rear lights M/// sport black grills
Has to be Marius doesn't it.bz4kev wrote: ↑Sun Mar 18, 2018 4:57 pmhow rude are you would not be expecting any help on here with comments like that sure DLV was only trying to help suggest you climb back in your box ( Marius)z4rumble wrote: ↑Sun Mar 18, 2018 4:03 pmYeah most people don't have an 8mm flex headed ratchet spanner buddy. OP don't listen to this snob.Ducklakeview wrote: ↑Fri Mar 16, 2018 10:41 am Just use an 8mm flex headed ratchet spanner. Makes access easy and turns it into a 10 min job.
Mike
SOLD
SOLD
- Havard
Unless there is someone else with a knob like toddler and also has a brain injury.??
Or use the right tool for the job...
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Mini 1000 1981
Toyota MR2 NA 1995
Mini 1000 1981
