Replacing rear quarter panel
- Mr Tidy
Hope you get it sorted OP - worst case scenario must be to head to the Black Country and "Nash3vans".
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
Gone - Montego Blue
Gone - Ruby Black
- longshaw
Hey, I have searched but cannot find the thread you speak of... I don't suppose you have a bookmark?
- markplant
I'll have a look
- markplant
See if this thread helps an let us know
viewtopic.php?f=3&t=112457&p=1622642&hi ... s#p1622642
In case he doesn’t find the thread, you need to climb into the boot on your back and loosen off the torx screws that hold the aluminum frame to the shell. Once you have enough loosened you need to tug the frame away from the area the bolt is, then loosen the bolt off from inside the boot.
A PITA to do - I’ve had to do it twice - and when I did it the second time I simply didn’t bother putting that bolt back on; the panel is held on there securely with like 7 other bolts. IIRC you need to have the roof delatched from the windscreen and only a couple of inches ‘down’ so there no tension on the roof whilst you’re loosing the frame and pulling it away.
Other than that it’s an easy job to do
- markplant
Or this one
viewtopic.php?f=15&t=77653&start=15
I replaced mine recently and the guide is in the “how to” section - far easier than unbolting the roof
viewtopic.php?f=28&t=121246
Sepang Coupe
Imola Roadster - For sale
Interlagos Coupe - For sale
Previous:
Stratus Grey Coupe
Titan Silver 3.0 Roadster
Carbon Black Coupe
Silver Grey MR
Silver Grey 3.0si Roadster
Maldives Blue 2.5
Sterling Silver 3.0 - twice
Previous:
Stratus Grey Coupe
Carbon Black Coupe
Silver Grey MR
Maldives Blue 2.5
- markplant
Forum power
- Vanne
doubt you can PDR that, its on the crease. The panel isn't welded in , but it IS glued on in several spots. Its not just undo the bolts and she comes right off.
can't you just bog it up and re-spray it?
Powered by Severn Tuning
- longshaw
Thank you thank you!
Hopefully get this pannel off and fixed up / put on replacement
- Sidewaze Samm
Might that depend on build date? I've swapped an O/S/R wing from a 06 to an 05 car and can't remember there being any glued areas on either car.
2008 E85 3.0si
Space Grey, Dream Red New England heated Msports.
Xenons, MFSW, cruise, PDC, wind deflector.
ZHP, stubby, gloss black grilles, DLV box, gaptech, no CDV.
I've had to swap out both rear wings and 1 front wing on a 03 E85; definitely not glued on that model.Sidewaze Samm wrote: ↑Fri May 01, 2020 3:09 pmMight that depend on build date? I've swapped an O/S/R wing from a 06 to an 05 car and can't remember there being any glued areas on either car.
