Inspection 1: Where to go?
barnyg
Post by barnyg » Mon Feb 19, 2018 1:50 pm
So looking at my dash I'm at around 10k until inspection 1 is suggested. However I am also approaching my MOT and I would usually get my car serviced with the MOT every year. Am I correct in assuming the best course of action is to just go with an inspection 1 for continuity?
Assuming this is right, does anyone have suggested of good Indies in the Woking/Guildford area? I have a good indy I would usually go to run by a friend, but they aren't BMW approved and want to keep the logbook looking healthy...as always I've checked the local BMW dealer for comparison (I know it's going to be much higher than an indie) and they're after £269 for the inspection 1 alone. It seems alot considering apparently it just includes an oil change and microfilter change...am I correct in that the spark plug changes are done during inspection 2? Lady on the phone also said they don't often do just oil services now which confused me a bit.
Any help much appreciated.
Barny :)
[SOLD] 2006 Z4 3.0si Coupe: Montego Blue, Cirrus Dash, Cruise Control, Nav, 18" CSL Reps, Eibach lowered, MM Tips, ZHP Gearknob, Sport Button mod, GROM BT3
ben g
Post by ben g » Mon Feb 19, 2018 1:55 pm
If you want to keep it correct, get an oil service done with your mot and then get the inspection 1 done when either your mileage countdown reaches zero or the 2 years is up.
Scooba_Steve
Post by Scooba_Steve » Mon Feb 19, 2018 6:59 pm
barnyg wrote: Mon Feb 19, 2018 1:50 pmdon't often do just oil services now
Go somewhere else.
Depending on your mileage you may want to start considering DIY or any other garage. Look at the service schedule, there's not much on there that isn't covered by the MOT. IMHO the intervals are too long, if you want to keep long term then have a google of lifetime BMW maintenance schedule, I subscribe to that school of thought.
maxman
Post by maxman » Mon Feb 19, 2018 8:36 pm
My son has used BMS Leatherhead ,he said they new their stuff.
Zeld4
Post by Zeld4 » Mon Feb 19, 2018 9:38 pm
I suppose technically you only need to get an inspection done every 4 years, alternating between inspection 1 and 2. I can’t see what harm just having an oil change in the interim years would do. I don’t know how many miles you are doing but 30 to 40 k miles between inspections are normal. My coupe has always got to its service time before the two years service interval and it’s on 125k miles on an 09 plate. It’s had 3 oil services at approx 20k 60k 100k and inspection 1 at 40k, inspection 2 at 80k and the last inspection 1 at about 117k. So that’s 6 oil changes in all and all work done was on time and in mileage schedule. Car gets regular use and burns a litre of oil about every 12k miles. If it sat around more I’d probably ge the oil done every year , but I just keep to the BMW schedule and everything seems healthy.
RickRob
Post by RickRob » Mon Feb 19, 2018 9:49 pm
It may be too far for you - 15 miles south of Guildford - but I recommend these guys and I know that a few folk on here use them too:
https://walkersautotech.co.uk/
They do courtesy cars.
Mr Tidy
Post by Mr Tidy » Tue Feb 20, 2018 12:51 am
For the last 3 years or so I've always used TWG Automotive in Camberley (01276 22733) for both my BMWs. The principal, Will, and at least 1 of his technicians are ex-Sytner. There is also a courtesy car for £15 a day IIRC, but if you want it you may have to book further ahead.
A couple of other form members go there too! :)
Coupes because stunning!
Gone - Montego Blue
Gone - Ruby Black
flimper
Post by flimper » Tue Feb 20, 2018 8:51 am
+1 for TWG
Piano black & black extended leather. Power mirrors, tinted glass, PDC, Prof hi-fi, CD, retro-fit cruise
Silverzedtom
Post by Silverzedtom » Tue Feb 20, 2018 9:36 am
I can’t help with a reccomendation but I would do an oil change yourself, making a note of it in the service record referencing the receipt for the oil. That way you still get fresh oil in there and don’t line someone else’s pocket when you don’t have to.
In my opinion a couple of extra oil changes done by the owner shows that it’s owned by an enthusiast.
E85 2.5si
F55 Cooper S
hopz121
Post by hopz121 » Tue Feb 20, 2018 2:54 pm
BMS Leatherhead or Munich Power in Redhill for me :)
2004 BMW E46 M3 Coupe - Manual - Silver Grey
2017 BMW F31 318d M-Sport - Auto - Glacier Silver
2007 Porsche Cayman 2.7 - Manual - Arctic Silver
2003 Renault Clio 172 Cup - Blue
2003 BMW E85 Z4 3.0i - Gone
2008 BMW E90 330i SE - Gone
R60BBA
Post by R60BBA » Tue Feb 20, 2018 2:59 pm
Munich Legends.
Current: 2002 E46 M3
Current: 2005 997 Carrera S
Gone: 2004 R53 Cooper S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
barnyg
Post by barnyg » Tue Feb 20, 2018 3:05 pm
Thanks for all the replies, have decided to get quotes from both TWG Camberley and BMS Leatherhead. The former sounds like it could be tough as apparently they're booking into April already!
As suggested, planning to go with an interim oil service plus MOT and brake fluid. Oh and a general health check to make sure everything else is ok. Tom, you make a good point but as I'm doing other bits anyway will go for the oil change at the same time for ease. Inspection 1 next on dash but 10,000 miles away, just wasnt sure about the whole alternating oil services and inspections thing considering it last had oil service.
Silverzedtom
Post by Silverzedtom » Tue Feb 20, 2018 3:23 pm
R60BBA wrote: Tue Feb 20, 2018 2:59 pmMunich Legends.
To say I was less than impressed by them was an understatement.
E85 2.5si
F55 Cooper S
hopz121
Post by hopz121 » Tue Feb 20, 2018 4:35 pm
Silverzedtom wrote: Tue Feb 20, 2018 3:23 pm
+1 Never again for me, they were great when I first went there years and years then shocking the second time around a year or so after and I never went back :)
Mike6
Post by Mike6 » Tue Feb 20, 2018 6:02 pm
For heavens sake dont ask for a general health check along with oil service and MOT. The MOT should cover everything and more that a general health check will achieve. The garage will simply add extra to your bill and not do anything. MOT and oil service should not amount to more than £120 as I suspect they will suck the oil out and not even remove the sump plug. Oh forgot the disposable glove so that will add another £100 please.
