Valve Cover Gasket Replacement
BSVA
Post by BSVA » Sat Feb 17, 2018 8:30 pm
I'm getting ready to replace the valve cover gasket on the Z (M54 3.0i), so could anyone tell me the bolt torque settings (ft lb) and torque sequence. Had difficulty looking on line. Thanks for your help.
2004 BMW Z4 3.0i, Titanium Silver, Black Leather, Premium Pkg, Sport Pkg, Xenons, Ellipsoids,
Continental ProContact RX SSR's.
Chris_D
Post by Chris_D » Sat Feb 17, 2018 8:37 pm
bolts have thread stops, i.e. they will physically stop at acertain number of turns so no fear of overtorquing or stripping threads.
more important is to pattern-tighten, preferably from the inside outwards.
i've done this to curtail my own 3.0i from decanting its' oil and worked a treat.
put some gasket maker on the corners and half-moons as they are known weak spots. i used aircraft-grade stuff. no leaks after a year.
good luck :thumbsup:
Online
patriot66
Post by patriot66 » Sat Feb 17, 2018 9:05 pm
Did mine last April. Very straight forward job.
All cover bolts are 10 Nm / 7.4lb/ft
I couldn't find a correct tightening sequence so just worked outwards from the central bolts in a sort of spiral. I used black JB Weld on the corners of the half - moons. All good and no leaks 10 months later. :thumbsup:
BSVA
Post by BSVA » Sat Feb 17, 2018 11:37 pm
Thank you Chris_D and patriot66 for the quick responses. Hopefully will tackle this job next week.
DaveZ4richardson
Post by DaveZ4richardson » Sun Feb 18, 2018 1:08 am
I just completed mine in January, no issues and no weeping oil since. Also changed the plugs when the cover was off.
DaveZ4richardson :thumbsup:
3.0i 2003 E85 auto cruise control, smart top module.
