E86 service intervals
alexparker
Post by alexparker » Tue Feb 13, 2018 1:11 pm
Hi everyone,
I'm considering a rather tidy E86 at the moment - low mileage, great spec etc. I have an issue with the service intervals in the logbook though - the gap between the pre delivery check and the first service is 22,000 miles/5 years. Inspection 1 was done after 25,000 miles from new. Cause for concern?
philbo909
Post by philbo909 » Tue Feb 13, 2018 1:26 pm
It's a long gap, but how many years ago? Has it been well serviced since? Test drive it and if it's all tight and nice I see no problem with it personally
Sapphire black z4 coupe 125,000miles young
hopz121
Post by hopz121 » Tue Feb 13, 2018 1:28 pm
Yep,
Servicing is every 2 years as a minimum regardless of mileage!
Service interval is as follows
Oil service
Inspection 1 Service
Oil Service
Inspection 2 Service
Oil Service
etc......
Coolant is every 5 years
Brake fluid is every 2 Years also
Haggle hard or find another one would be my view on it.
5 year old oil isn't good for an engine.
Now - 2004 BMW E46 M3 3.2 Manual Coupe, Silver Grey :D
Gone - 2003 BMW Z4 3.0i M Sport Vert, Sapphire Black :(
Gone - 2010 BMW 123d MSport Hatch, Sapphire Black
Gone - 2006 Ford Focus ST3 3 Door Hatch, Performance Blue
alexparker
Post by alexparker » Tue Feb 13, 2018 1:36 pm
Cheers for the replies. It's 12 years old, but has only had three services (the third being a few weeks ago). Oil change, then inspection 2, then inspection 1.
hopz121
Post by hopz121 » Tue Feb 13, 2018 1:38 pm
Your call plenty of other cars about though.
Id take a cheaper car with more miles that has been serviced correctly personally.
philbo909
Post by philbo909 » Tue Feb 13, 2018 2:05 pm
A service every four years is bad news, best to steer clear if it's priced as a pristine low miler
philbo909
Edit: double post
Online
mjennings23
Post by mjennings23 » Tue Feb 13, 2018 2:51 pm
Agreed, but then I'm a stickler who does at least an oil service every year despite only doing 8k miles. Its so cheap if you do yourself that it's not worth leaving, £50 for filters and 10l of oil is nothing.
alexparker
Post by alexparker » Tue Feb 13, 2018 2:55 pm
My feelings exactly... thanks
Online
rally-chris
Post by rally-chris » Tue Feb 13, 2018 4:40 pm
There’s only one significant risk resulting from long service intervals on low mileage cars and that is the build up of moisture in the engine oil. Most of the service items are just checks or replacement of items that don’t have a long term harmful effect on the car (like an air filter).
If this car had only one 4 year service gap and then regular servicing over the subsequent years then I wouldn’t be too concerned as any damage to the engine (due to corrosion) will likely have shown up by now (e.g. damage to crankshaft or camshaft bearings etc). However if the car has continued to have long service intervals since then, I would be more circumspect as problems may yet surface.
Chris
08 Z4 3.0si Sport Coupe in Montego Blue
Who is online
Users browsing this forum: 1000rr, DanYelSun, greg81, heavymetalthunder, mjennings23, Mos6689 and 33 guests
