E85 roof
Scott S
E85 roof
Post by Scott S » Sun Jan 21, 2018 9:18 pm
Hi all
Can anyone tell me please. Can you use black shoe/boot polish on the roof. If so what's the procedure.
Regards
Scott
Crazy Harry
E85 roof
Post by Crazy Harry » Sun Jan 21, 2018 9:44 pm
Hi Scott, what problem are you trying to fix?
Number5
E85 roof
Post by Number5 » Sun Jan 21, 2018 9:52 pm
Yes, mix it 50/50 using liquid polish with the Autoglym roof protector and it comes out a treat :thumbsup:
Alpina Roadster #307
Porsche Boxster GTS
Previous Zs
Stratus E86
G29 30i
1x Imola Z4MR
Alpina #019
10x E85 Se/Si Roadsters
2x E89's
buzyg
E85 roof
Post by buzyg » Sun Jan 21, 2018 9:53 pm
Never heard it done. But apparently it works a treat.. :thumbsup:
Chris_D
E85 roof
Post by Chris_D » Sun Jan 21, 2018 9:58 pm
the outer black layer is meant to be porous, allowing water/rain/moisture to permeate through to the waterproof membrane beneath it.
anything which impedes this process e.g. waxes/oils is a disbenefit to the overall condition of the outer layer.
Scott S
E85 roof
Post by Scott S » Mon Jan 22, 2018 8:18 pm
Would this be liquid shoe polish that you can buy from tesco's, that you just dab on to your shoes. Sorry I'm sounding a bit derrrrrr. Just that it's a big job that could go horribly wrong.
Hearing what Chris D is saying, is making me think I shouldn't do this. :wink:
Scott S
E85 roof
Post by Scott S » Mon Jan 22, 2018 8:21 pm
Crazy Harry wrote: Sun Jan 21, 2018 9:44 pmHi Scott, what problem are you trying to fix?
Hi. There no problem I just thought it might have been a good idea. I just wanted to know dosage and process really
Cheers scott :driving:
Scott S
E85 roof
Post by Scott S » Mon Jan 22, 2018 8:22 pm
Number5 wrote: Sun Jan 21, 2018 9:52 pmYes, mix it 50/50 using liquid polish with the Autoglym roof protector and it comes out a treat :thumbsup:
What would be the process please
Cheers Scott :driving:
Crazy Harry
E85 roof
Post by Crazy Harry » Mon Jan 22, 2018 8:36 pm
Scott S wrote: Mon Jan 22, 2018 8:21 pm
They can tend to go a bit 'green' over a damp winter - I can see a slight tint on mine so it will get a scrub over with 'Milton fluid'. Then first dry day a going over with a stiff (plastic bristle) brush and the vacuum cleaner - I kid you not. This gets the majority of dirt out of the fibres then hot soapy water. Its amazing how well they come up.
If its fading then the treatment outlined above will darken the colour. The top layer doesn't have to be sealed there is a waterproof membrane under the outer layer.
RickRob
E85 roof
Post by RickRob » Mon Jan 22, 2018 9:58 pm
Adding a bit more to the above.
The AG roof cleaner kit has a protector which is waterproof. I say this because when just done the water beads just like water on polished paint. Some people think this is OK, others say it can mess with what the construction of the roof is supposed to do; I.e the top surface is porous and a lower level is waterproof.
Therefore adding liquid shoe polish to the AG product isn't going to make the roof any more waterproof.
If I were you I'd give the roof a really good clean with the AG kit, having vacuumed it first. With mine that got it all back to black!
mjennings23
E85 roof
Post by mjennings23 » Mon Jan 22, 2018 10:02 pm
I'd agree with the above, just get a proper brush as the sponge supplied with the AG kit is as useful as a chocolate teapot.
I use a Vikan soft top brush personally with the AG soft top cleaner, although I expect Renovo or similar will be equally as effective.
I did actually give it a coat of Renovo restore after the first proper clean and that got the roof back from a bit faded to proper black.
Davz
E85 roof
Post by Davz » Tue Jan 23, 2018 12:07 am
Treat your softtop with as much care as possible if you want it too last.
When I treated mine before winter, I hoovered it all over to remove loose dirt/debris, washed it with baby shampoo - no harsh detergents, using a very soft baby nail brush (couple of quid at boots) this gets out any ingrained dirt. Washed the soap away using a watering can starting from the top down. Allowed to dry and treated with Grangers Fabsil waterproofer, online about £10 litre, brushed on with a 1.5" paint brush, working from one side over to the other. Fabsil will make your softop look like it has just come out of the factory, will UV protect and beads brilliantly! I wouldn't use anything else.
https://www.winfieldsoutdoors.co.uk/gra ... o_s=gplauk
2006 2.5 Monaco blue, orange footwell lights, Blue boot lights, 20/15mm wheel spacers, Buckley06 gear knob, Aux, MV2's, M pedals, Eibachs, Bilstein B4's, Whiteline front ARB. H&R rear ARB. Roof motor relocated, Alpine speakers, Xenons.
Monkeydonkeyratmagic
E85 roof
Post by Monkeydonkeyratmagic » Tue Jan 23, 2018 7:02 am
Best thing for cleaning it is baby item sterilisation tablets. Kill the germs and bacteria right off without any harmful chemicals at all. Works an absolute treat and costs next to nothing. Just dissolve in warm water and off you go.
MR-2 Turbo Rev2
Yep no Z yet. On the hunt.
Scott S
E85 roof
Post by Scott S » Tue Jan 23, 2018 9:26 pm
Crazy Harry wrote: Mon Jan 22, 2018 8:36 pm
RickRob wrote: Mon Jan 22, 2018 9:58 pmAdding a bit more to the above.
Hi, I did Hoover the roof, cleaned it then treated with some sort of camping seal. This seems to have work. I've had the car covered a fair bit over this winter. There is t any green on the roof at this moment.
I can't wait for it today up, get warm then I can get the car clean and get driving. :driving:
Scott S
E85 roof
Post by Scott S » Tue Jan 23, 2018 9:28 pm
Hi all
All these tips are really useful and helpful.
Cheers to all
Scott
