Work completed since March :)
markalp
Post by markalp » Wed Jan 17, 2018 2:55 am
kis wrote: Tue Jan 16, 2018 7:47 pmI thought it was something codeable too? Does anyone know? For the pre facelift...
I seem to remember reading in the handbook of my Alpina which is the pre facelift, when braking hard the whole ring of the rear lights light up rather than just the outer arc of the brake light, no mention on flashing the brake lights.
I have never actually seen it happen though because i'm always driving lol
Alpina Roadster S LUX #030
kis
Post by kis » Wed Jan 17, 2018 12:34 pm
Coffee331 wrote: Tue Jan 16, 2018 11:03 pmIt’s nothing to do with G spots :rofl:
I had bought a G Stop for my main car and they emailed me with offering a second unit massively discounted so I thought why not for the Z :)
Is it a discount code? Maybe you could share it in a PM? :D
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
Coffee331
Post by Coffee331 » Wed Jan 17, 2018 11:16 pm
kis wrote: Wed Jan 17, 2018 12:34 pm
It was April last year that I got the code. They are only £8.99 on Amazon now so pretty cheap even without a promo code :)
GSTOP ® LITE Accelerometer G-Force Monitor Brake Light Flasher - Retrofit EBLD System https://www.amazon.co.uk/dp/B01IW2RBJA/ ... xAb9SYXFNH
kis
Post by kis » Fri Jan 19, 2018 10:12 am
Coffee331 wrote: Wed Jan 17, 2018 11:16 pm
Any pics of where/how you fitted it? Not so worried about actual wiring, just best placement of the unit and where you found best to cut into the wires. :)
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
Coffee331
Post by Coffee331 » Sat Jan 20, 2018 3:15 pm
I fitted it to the underside of the boot and tapped in to the wires of the middle brake light. You just cut the factory wires and wire this in to the feed. It’s important that it’s placed flat(ish) for the G sensor to be able to function correctly under heavy braking.
kis
Post by kis » Mon Jan 22, 2018 11:37 am
Will have a snoop in the boot this week and put this on my list. Coding is hit and miss with the pre facelift. Not found anyone to confirm if it can be coded or not. And if I can achieve the mod for under a tenner then I'm not complaining!
My E85 Z4 3.0i SMG
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
