Painting new disks
Silverzedtom
Painting new disks
Post by Silverzedtom » Sat Jan 06, 2018 6:53 pm
Just had new disks and pads arrive and want to paint the disks to prevent the rust.
Question is should I spray the inside of the hat’s or leave them as they are? My concern is the handbrake shoes on the rear’s.
The second concern is the mating surfaces. I wasn’t going to spray the faces but can’t make up my mind. They will have a couple of weeks to dry before they are mounted however this might mean the surfaces are no longer perfectly uniform.
Hopefully you’re all going to tell me to spray the lot as it’s easier :roll:
Any thoughts appreciated :thumbsup:
2.5Si sport titan | Syrah blue interior | CSL reps | ZHP gear knob | Eibach pro kit springs | CDV delete | Wiechers racingline strut brace | Ram air scoop | Matt grill | Blue Calipers | de-badged | muffler delete | K&N | CF skirt extensions | Stubby
Smartbear
Painting new disks
Post by Smartbear » Sat Jan 06, 2018 7:06 pm
Hi, I wouldn’t spray inside the drum where the shoes live-leave that bare metal.
I’ve sprayed the outside part that contacts the wheel and had no issues, it’s only a thin coating & soft enough for the wheel to pull up squarely with the torquing of the wheel bolts :thumbsup:
e89 Sdrive2.0 18i, which has turned into a 20i :D
e89 Sdrive3.0i this ones busted, pass me another...
e85 3.0si, i sold my trouble free car...
Silverzedtom
Painting new disks
Post by Silverzedtom » Sat Jan 06, 2018 7:30 pm
Cheers Rob. Thought that would be the case Re shoes. Looks like I’ve sorted out my plans for tomorrow morning. :)
patriot66
Painting new disks
Post by patriot66 » Sat Jan 06, 2018 7:45 pm
I never paint the face that the wheel mates up to. A very thin coat of Coppaslip prevents corrosion and the wheel adhering. :thumbsup:
'03 Sterling Grey 2.5i SE / Sequential Manual Gearbox / Matching Hardtop / Gloss Black MV3s / Bilstein B4s / Carbon-wrapped Interior Trim / Re-Covered Steering Wheel / Clear Indicators / All by my own fair hand !
cj10jeeper
Painting new disks
Post by cj10jeeper » Sat Jan 06, 2018 8:55 pm
Agreed - never paint mating faces.
Peterboroughdave
Painting new disks
Post by Peterboroughdave » Fri Jan 12, 2018 11:34 pm
I am a little confused about the not painting the mating surface, i understand the risk of uneven coating resulting in miss-alignment, but if this is a real issue then what about the paint applied to the inner face of the wheels, which are subsequently bolted up against the face of the disc mounting surface. ?????
When I refurbished my discs I did not paint the mounting face, however I would like to as the disc mounting diameter is about 30 to 40mm more than the wheels mounting face, hence an annulas that has gone rusty
Usel
Painting new disks
Post by Usel » Fri Jan 12, 2018 11:57 pm
The original paint on the discs will probably have been baked so its throughly dry or hardened. The paint you use even when dry will still be soft. When you put the wheel back on the disc could stick to the wheel. Think of when painting wooden windows or maybe doors. When dry you shut them and when you next open them they stick and need an impact force to open.
This could happen to your wheels and won't be fun if it happens.
cj10jeeper
Painting new disks
Post by cj10jeeper » Sun Jan 14, 2018 12:05 am
Simply speaking the chances of you painting the mating surfaces and getting a flat surface are close to nil. Contaminants, blobs of paint, runs, etc will make the wheel out of true
Do it and it may get away with it, but I keep mating surface 100% clean and flat
mr nurburgring
Painting new disks
Post by mr nurburgring » Sun Jan 14, 2018 5:22 pm
Just spray the disc face and hub part with zinc etch primer, super smooth Finnish and will stay rust free for years.
Nictrix
Painting new disks
Post by Nictrix » Sun Jan 14, 2018 6:06 pm
Do you take the paint of the surface of the disc the pads run on before installing or let the pads take the paint off contaminating the new pads with paint on the first rotation of the wheels?
When I painted mine I masked off the pad area and only painted the part the pads dont run on.
E89 2010 23i M Sport Black with Black leather
Smartbear
Painting new disks
Post by Smartbear » Sun Jan 14, 2018 6:29 pm
I don’t think the paint would harm the pads, it’s not like oil which could soak in & contaminate them-a couple of brake applications and it’s gone :thumbsup:
mr nurburgring
Painting new disks
Post by mr nurburgring » Sun Jan 14, 2018 8:50 pm
It’s only a thin coat, just let the pads rub it off. It turns into dust and disappears leaving a nice edge.
