wipers?
ph001
wipers?
Post by ph001 » Thu Jan 18, 2018 4:36 pm
TomK wrote:
Thu Jan 18, 2018 4:05 pm
What do modern wiper blades do that 10 yr old ones don't out of interest?
Perhaps don't do anything particularly new, just do what they should do better! For example the Michelin ones seem to address the main gripes I have:
  • Independent Suspension Tertiary:
Adjusts to windscreen’s shape/curvature to help maintain complete wiper blade contact.
  • Smart Flex Secondary:
Holds wiper ends down on windscreen for optimum wipe performance.
  • Riveted Smart Hinge:
Provides maximum lateral strength to eliminate twisting of the frame during the wipe and to hold a secure, consistent position on the windscreen.
  • Actively responds to windscreen shape or curvature across the entire wipe pattern.
Then you have the special coatings like the Graphite on the Lucas Clearvision. They are certainly not all created equally. Anyway, I have the Michelins on order so will be sure to post an unbiased review when I test them out.
2004 E46 M3 coupe manual.
Buckz
wipers?
Post by Buckz » Thu Jan 18, 2018 4:50 pm
updating this, I have had a set of michelins on the car for a while now and they wipe really well and are much quieter than the bosch I had on before.
there's a problem that the passengers side still hangs in the air(too long I guess) and it is pressed too much against the windscreen which results in a "small" tick every time the passengers side wiper moves..
ph001
wipers?
Post by ph001 » Thu Jan 18, 2018 4:57 pm
Were they the Stealth? As Ben G stated, the 19" & 20" might actually be the optimal size.
Buckz
wipers?
Post by Buckz » Thu Jan 18, 2018 5:22 pm
yup, 20/21 inch as recommended by BMW but I am sure a shorter wiper would work better on the passengers side. Drivers is fine.
TomK
wipers?
Post by TomK » Thu Jan 18, 2018 5:52 pm
Thing is, the oem ones do all of the important bits of that better than the newer 'improved' ones I tried.
Anyway, let us know how you get on with the Michelins, I'm all for using them if they fit properly and are cheaper.
MC IB, CSL intake, Schrick 288/280 cams, SS race bbox, APs, RS-29s, Apex ARC-8, AD08-Rs, KW ClubSport, Turner arms & RTAB limiters, Vibratec mounts, Rogue pulleys & RSMs, Sparco carbon w/ 6 point, CDV delete, UUC ssk, M5 knob, oem strutbrace
ben g
wipers?
Post by ben g » Thu Jan 18, 2018 6:19 pm
Only reason i went an inch less on the drivers side is because when i watched it go through a wipe sequence, the drivers side one touched the windscreen seal at the top a small amount.
Unsure whether anyone else has noticed this. It was literally a very tiny amount of overlap, so i may just be over-cautipus, but it doesn't affect anything performance wise.
Red Soft-top Sterling grey 3.0i - Z4M Front, Eibachs, Polybushed, Bilstein, Clear headlights, Triple clear spot rear lights, Sport MFSW, ZHP, Gaptech RCH+, Strut Brace.
ph001
wipers?
Post by ph001 » Mon Jan 22, 2018 12:21 pm
Update on the Michelin Stealth hybrids... rubbish! Well, they wipe ok I guess but the egde is lifted off the windscreen even more than the oem and the worst thing is an annoying ‘clack’ noise every time they change direction. I think that was also reported by another member. They are going back for sure.
Might give the Lucas ones a go.
ben g
wipers?
Post by ben g » Mon Jan 22, 2018 12:51 pm
Thats why you buy them an inch shorter :headbang:
Is that 'clack' noise when they are at their lowest point, just before they come back up? If so, i've had that with every set i've tried. I can only guess they rub on the scuttle panel slightly.
Tcochrane92
wipers?
Post by Tcochrane92 » Mon Jan 22, 2018 1:14 pm
For the Michelin wipers:
Recommended sizes are 19" & 21", is that correct? For an E85
I couldn't find them on the Costco website, do they still stock them in store? Are they cheaper than Amazon?
https://www.amazon.co.uk/Michelin-Steal ... elin+wiper
Current: Silver Grey Z4mR & Ocean Blue BMW S1000XR Sport SE
Past: Silver Grey Z4C Auto & Titan Silver Z4 3.0i
Buckz
wipers?
Post by Buckz » Mon Jan 22, 2018 1:22 pm
yup! that was me. That clack is getting on my nerves.
