Would like to borrow - AFe Stage 2 Heat Shield
Following on from the air scoops, I'm thinking of making a (very similar) copy of the Afe stage 2 heat shield, which fully encloses the filter.
I can definitely cut the shape, bend, weld and powder coat them easily and for a lot less money than Afe charge.
The issue is that I need one to borrow one, to measure and produce a near-exact replica.
So the question is, does anyone have one to lend for a few weeks max. It's a long shot I know but maybe someone's car is starting hibernation and would like to help out?
I've had a message today asking and the end goal is to offer these on the forum, should people be interested.
Any and all comments welcomed
- JINGLE
This looks interesting.... does it only fit certain engines or universal ?
Haha, I’ve just pmed you as thought you may have some input!! Looked on here and you’d beat me too it!!
Afaik they fit all models but would be easy to make. I’ve not heard one personally but they’re supposed to sound really good.
- JINGLE
Hah you know me too well!
Happy to put my name down as all previous parts have been more than happy with
I have an AFE intake and coincidentally I’m about to remove it from my car.
Where are you based dans6490?
I’m removing it to trial the standard air box with a K&N panel filter. It could also benefit from a re protection (powder coat) whilst removed as it’s been on the car for quite some time. I’m down in Surrey.
- Darkangelv2
As per your scoop - registering major interest right now!
BMW Z4 2006 2.5SI - 437M Wheels - Strut Brace - H&R ARBs
3.0si Brake Conversion - Custom Nappa Sport Interior - Z4M Bumper+Bonnet -
BC Racing BR Coilovers - AFE Stage 2
Great, will update here with progress.Darkangelv2 wrote: ↑Wed Sep 27, 2017 11:16 am As per your scoop - registering major interest right now!
- Darkangelv2
Hi Dandans6490 wrote: ↑Wed Sep 27, 2017 11:49 amGreat, will update here with progress.Darkangelv2 wrote: ↑Wed Sep 27, 2017 11:16 am As per your scoop - registering major interest right now!
Would you just be looking at the metal fabrication or looking into the replacement hose post-enclosure (i believe it hosts the MAF and joins into the plenum)?
I was initially thinking to sort the metal fabrication.Darkangelv2 wrote: ↑Thu Oct 05, 2017 12:43 pmHi Dandans6490 wrote: ↑Wed Sep 27, 2017 11:49 amGreat, will update here with progress.Darkangelv2 wrote: ↑Wed Sep 27, 2017 11:16 am As per your scoop - registering major interest right now!
I’ve since also been thinking about the filter/hose as it would need to fit the hole enclosure properly. I had thought about making it, so that a K&N cone filter/hose would fit perfectly. They seem easily accessible and people could then source that part separately but also be sure it’ll fit.
Not sure how it would work if people wanted to use another brand as it might not be a good fit. Z4 3.0si will hopefully have one to lend shortly, so I can take a good look at how it’s set up and how the filter/hoses fits.
If anyone can think of another solution I’d be happy to listen
- C8H18
Kinda dragging up an old thread here (it popped up in a search result). Did this get anywhere? I'd certainly be interested if it did
2006 silver / muddy 3.0si roadster manual
- Silverzedtom
