My 2003 E85 Custom Headlights. [Pic Heavy]
- Buckz
Like them! Much better than the aftermarket setup thats sold here.
- kis
Aftermarket? For xenon? Didn't think any existed? Link?
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- IAmOrion
I have them discs, but it's better to use something that "cuts" whereas those discs tend to melt their way through plastic. Needed a decent "straight" cut that would be easy to silicone seal shut again. Not to mention those discs are very weak and snap far too easily and wouldn't have been mush use I don't think for a project such as thisthanatu55 wrote: ↑Fri Sep 08, 2017 6:03 pm A 426 cutter for your dremmel would have been a lot less destructive (to the light and your finger ) -
https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1
Thanks, and Thanks
Thanks I hadn't seen any Xenon Aftermarkets (I don't believe they're available) and I'm very happy with the end result if I do say so myself
As mentioned above, AFAIK they're not
NO LONGER OWN A Z4 SO NOT AS ACTIVE HERE ANYMORE (IF AT ALL).
I STILL OFFER FREE CARLY CODING & EWS KEY/TRANSPONDER CODING AT MY HOME
IN CAMBRIDGE CB22
Facebook: https://www.facebook.com/groups/Z4DIYCustomMods/
IN CAMBRIDGE CB22
- thanatu55
It's what I used to do mine, but your solution is probably better. I like your attention to detail, the 3d printer etc. They've come out really really well. Very modern looking.
- IAmOrion
Ah ok - my experience with those discs hasn't been great so I tend to use them on ly on small or intricate things
Thanks again gotta consider my next mod now
I plan to cut the "BMW" out of the sills you sent me, and then use some EL Tape (although I may fabricate some kind of LED panel as EL isn't very bright) to illuminate the "BMW" lettering if that makes sense?
Other than that I need to get around to the finishing of my double din fascia
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- thanatu55
You're like me, a million different jobs in mind and onto the next one while the last one's still warmIAmOrion wrote: ↑Fri Sep 08, 2017 6:32 pmAh ok - my experience with those discs hasn't been great so I tend to use them on ly on small or intricate things
Yep the lit sills make sense........
The EL tape idea is an interesting one, I'd like to see it in practice, with the BMW lit up could look good.
- IAmOrion
Haha, yes indeed! Always the next mod on the mind
Ah yeah, I love those sills BUT I didn't want to spend the £100 odd or whatever they cost so thought I'd look to make my own. I do think though that the EL Tape will be rubbish so will most likely have to figure out a better DIY method (You know, unless anyone wants to sell me a set of the illuminated sills for £20 )
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- thanatu55
Ha I think I've supplied you plenty!IAmOrion wrote: ↑Fri Sep 08, 2017 7:07 pmAh yeah, I love those sills BUT I didn't want to spend the £100 odd or whatever they cost so thought I'd look to make my own. I do think though that the EL Tape will be rubbish so will most likely have to figure out a better DIY method (You know, unless anyone wants to sell me a set of the illuminated sills for £20 )
For what it's worth I find my sill's quite annoying, I'd rather they just lit and stayed lit but they do this whole demo thing and start to flash. And I need to hide the red wire.
Maybe consider an LED strip underneath with a glow sequence or 'dream sequence' as they seem to be referred to as. I have some around the back of my TV and they're mega bright and could look pretty cool for what you want to do. Or maybe EL wire around the lettering?
I'm sure you'll come up with something. It's far more satisfying when you've done something yourself and it pays off. Don't buy annoying sills!
- IAmOrion
Haha, and I'm very appreciative lolthanatu55 wrote: ↑Fri Sep 08, 2017 7:17 pm Ha I think I've supplied you plenty!
Yes I think it would most likely result in an LED strip of sorts (with a thin panel to disperse the light) Just depends on how the EL tape works out really. I mean realistically during the day I'm not bothered about seeing them glow, it's only at night does the effect really show itself off so to speak IMO.
Ha yes DIY stuff is awesome. I've done hundreds of arduino based projects too so I'm more than comfortable at writing my own code and creating animations and stuff with LEDs
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
- thanatu55
That's something I could never get my head round, if it involves code then I've got no chance. If it's just for night then I reckon the tape might be ok, I was about to say I've got some aqua blue tape you can have if you want, but it looks like I did half a job before I bailed on it. I planned on using it beneath the TV unit but never bothered, however for whatever reason I seem to have taped it all together into one long strip
Hey orion,
Sorry to dig up an old thread. You mentioned in the first post that the inner hole for the angel eyes was larger which required custom spacers. Would buying larger rings solve the problem? If so, what size do you think would work?
- thanatu55
I think the rings go up in 10mm increments. 90mm would be far too big and would probably look a little odd. I'd stick with all 80mm rings.
- IAmOrion
As thanatu55 says above, They wouldn't fit - you need to stick to 80mm. 80mm is the largest you can use
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
Thanks thanatu55 and orion for the quick replies!
- IAmOrion
Where are you based? I can print you off a pair
IN CAMBRIDGE CB22
IN CAMBRIDGE CB22
