Cheers but I was more interested in the light quality (brightness, illumination evenness, colour)
HOW TO; Convert Angel Eyes to BRIGHT LED's
Current: 06 E85 M Silbergrau
Previous: E85 3.0si Silbergrau, 03 E85 2.5i Maldives Blue.
Mods: Gaptech OTH+R, Dension Gateway 300 with USB, CDV-, clear side indicators, euro tails, stubby, MFSW retrofit, OEM Bluetooth/VR
- philbo909
I'll take a picture for you tonight
Sapphire black z4 coupe 135,000miles young
- philbo909
Hope this helps, definitely seem dimmer than I remember them being when the xenons are on too
- DSC_0957.JPG (50.44 KiB) Viewed 1331 times
- DSC_0960.JPG (84.11 KiB) Viewed 1333 times
- DSC_0958.JPG (61.42 KiB) Viewed 1333 times
Cheers mate! I've got some eBay units on the way so we'll see how the go
- 85genius
Just wanted to check did these need coding out or completely error free?philbo909 wrote: ↑Sat Oct 28, 2017 9:57 am not to rain on your parade mike, but if you drill two small holes, the light can come out as a bayonet. Then replace with a bayonet led, saves on dremeling/soldering
http://www.ebay.co.uk/itm/BA9S-CAR-BULB ... 68Mkocsn1w
Audi quattro driver
NOW SOLD - Ruby Black 3.0 SI Roadster
Previous - E85 2.5 Ti Silver - See avatar photo - R.I.P Destroyed by a Tranny
- Ducklakeview
Unsure on the eBay ones but mine were fine with no errors.85genius wrote: ↑Mon Oct 30, 2017 11:43 amJust wanted to check did these need coding out or completely error free?philbo909 wrote: ↑Sat Oct 28, 2017 9:57 am not to rain on your parade mike, but if you drill two small holes, the light can come out as a bayonet. Then replace with a bayonet led, saves on dremeling/soldering
Mike
- Markos_Z4
i've changed the lamp but not break it like you did . . .just cut it open with a knife
M-Front & M-Rear Bumper / Aero Skirts / 9J + 10.0J 20 inch Barracuda Voltec T6 gloss black inox Lip / Custom Quad Exhaust / Gloss Black Painted Roof / Gloss Black Painted front Lip / M-Sport Suspension / M-interior
Follow me on Instagram https://www.instagram.com/markos_z4/
- Markos_Z4
buy this one perfect fit just make small a small cut on both sides and slide it in !
- philbo909
Sorry I missed this, I coded out the lights when the sidelight initially broke. Not sure if I coded the warning back in when fitting them85genius wrote: ↑Mon Oct 30, 2017 11:43 amJust wanted to check did these need coding out or completely error free?philbo909 wrote: ↑Sat Oct 28, 2017 9:57 am not to rain on your parade mike, but if you drill two small holes, the light can come out as a bayonet. Then replace with a bayonet led, saves on dremeling/soldering
So I tried out a similar bulb to what Philbo linked but it's just as dim as the stock halogens: http://www.ebay.com.au/itm/2-x-BA9S-Bay ... 3285449298
They were also really blue looking :/
It seems that when looking for a suitable LED bulb you need to check that it's a decent wattage/lumen output and also look for a warm white colour. I'll grab some others to try!
- McKoval
Can these be used as DRLs, or are they not bright enough?
- Ducklakeview
- McKoval
Yes, I know. Coding drls is plain and simple, but whilst I had i coded that way, I had to decode it, as police stated that my drls arent bright enough (stock angel eyes)
any updates? any links for the bulb replacements? Any fitting issues or have they become dimmer over time?
Thanks.
Thanks.
2007 Z4 3.0si Bright red
- scarlet-jester
I would like some info on this too.
I have found these, https://www.trademe.co.nz/motors/car-pa ... 77697a3fe1
but they are a BA9S; is this the correct fitting?
E85 - 2006 3.0Si
