I think a bit of research is neededshuey said:Hey all, I will soon be buying a z4 coupe, sport.
Without going into a big debate about which is better or which is more reliable, if you could pick z4 coupe with either of the engines, which engine would you go for? Thanks peeps
shuey said:if you could pick z4 coupe with either of the engines, which engine would you go for?
kis said:I disagree. I see it as a hypothetical question.
But agree the question should be worded better to indicate whether hypothetical or whether it’s just knowledge gap.
R60BBA said:
ph001 said:N52:
Electric Water pump (£200 to replace, easy enough to change DIY)
CCV on silver top engine can get gunked up (later revised black top engines have integrated CCV which is more difficult to change but doesn't seem to got wrong as often)
Valvetronic can be a bit ticky due to airlocks / sludge build up with lots of small stop - start journeys but not detrimental to engine.
Steve84N said:S65 is more than M54 or N52 but less than S54.
srhutch said:I would also argue it is detrimental to engine as it's metal on metal contact with impact.
