Anyone know what this is for?
- Optinium
Found loose behind the glovebox without anything to visibly plug in to.
Youtube: Car Beard Instagram: its_car_beard
Current: 2015 F-Type R RWD, 2022 Tucson N-Line S
Gone: 2021 GR Supra Pro 2007 E86 Z4MC 2016 F-TYPE R AWD Convertible, 2014 F-TYPE V6S, 2007 E86 Z4MC, 2010 E89 Z4 23iSdrive
- enuff_zed
Sorry, can't view the image
- Optinium
Should be good now?
Just check as have Dash board out and only likely plug would be the air bag….
The other 2 wire plug is the under dash light
Just a quess but could that be for the glovebox light.
- Optinium
Thanks for the suggestions, I found what it was, looks air con/heater related, ill post an image/info later as to what it was
Yes ..very likely …just checked again
- Rockhopper
Airbag and SRS wires tend to be yellow.
- Optinium
So from what I can make out it was an actuator for directing the air flow to the cabin. Must have come loose when I originally removed the GM base unit.
All back in now.
Thanks again people for the suggestions etc...
All back in now.
