Early (2003) Rear Calipers
- Ratcatcher
As part of the ongoing refurb, i was thinking of swapping out the rear calipers with some exchange units but i noticed the websites state a difference between vented or unvented discs. My rear discs are currently vented but i suspect a previous owner fitted these so im now unsure whether these are standard ie were they unvented previously Or, were the vented ones standard on a 2003 2.5i?
The obvious answer here is that the current calipers wouldnt have fitted vented discs if unvented were original, but i just wanted to make sure before i purchase.
As usual, any info is much appreciated.
“Rules are for the obedience of fools and the guidance of wise men.” ― Douglas Bader
- BumpyZ4
According to RealOEM the 2.5 came with non-vented discs. I check up to 11/2005 build date.
2003 E85 3.0i Sterling Gray
KLR 650
Diva Roadster (Kit Car)
KLR 650
- Ratcatcher
Good plan, and yes youre right, the non vented discs are for the 2.0/2.2/2.5 and vented for the later 2.5si/3.0 models. So i have the 'wrong' discs on the back. Question is, do i have the matching calipers........
- patriot66
The answer to that question is yes. The calipers that fit over an unvented 2.5i rear disc are physically 'narrower' than the 3.0i calipers that fit over the physically thicker vented disc.Ratcatcher wrote: ↑Mon May 10, 2021 10:31 pmGood plan, and yes youre right, the non vented discs are for the 2.0/2.2/2.5 and vented for the later 2.5si/3.0 models. So i have the 'wrong' discs on the back. Question is, do i have the matching calipers........
I have just recently completed a 3.0i brake transplant onto my 2.5i using a mixture of new and old refurbed parts. Just for your information the front calipers are common to 2.2i, 2.5i and 3.0i. It is the disc size (300mm dia) on the 3.0i that is bigger and the actual caliper carrier is 'larger' placing the caliper further out on the larger diameter disc.
Photo of rear 2.5i unvented disc Photo of rear 3.0i vented disc and 'wider' calipers Have a look on https://www.realoem.com/bmw/enUS/select
for all the parts numbers
- Ratcatcher
Cheers! Yeah, i looked at new discs last night and the unvented are 10mm thick whereas the vented are 20mm. Im coming to the conclusion that the unvented calipers wouldnt physically fit over the vented discs and looking at your photos, theres a definite difference in the throat profile of those calipers. I shall check later which ones i have.
- Ratcatcher
Well, something didnt look quite right to me so after a chat with my local BMW garage, the parts guy volunteered to order the caliper and mount in for me to look at. Top Man! It seems that it is possible to fit the wrong caliper on the vented discs but i suspect they will only work with full pads. Anybody have a pair of 3.0l rear calipers they dont need????
- patriot66
I agree, theoretically possible to fit the 'wrong' 2.5i calipers over a 3.0i 20mm thick vented disc. However, there wouldn't be much room for full pads, if any at all....they would have to be down to the backing plates !Ratcatcher wrote: ↑Fri May 14, 2021 4:00 pm Well, something didnt look quite right to me so after a chat with my local BMW garage, the parts guy volunteered to order the caliper and mount in for me to look at. Top Man! It seems that it is possible to fit the wrong caliper on the vented discs but i suspect they will only work with full pads. Anybody have a pair of 3.0l rear calipers they dont need???? PXL_20210514_130805831.jpgPXL_20210514_130753006.jpg
Have a look at the these two photos:
1) 2.5i caliper and carrier, 10mm unvented disc, almost new with almost new pads 2) 3.0i caliper and carrier, 20mm vented disc, almost new with brand new pads As you can see you definitely couldn't squeeze a 2.5i carrier over a 3.0i disc !
- Ratcatcher
I hear you, but thats whats been fitted to my car. ie smaller carrier and caliper on a vented disc! I did think that it might have been larger carrier and smaller caliper that had been used hence the check with both stock items.
If i get chance ill remount the brakes later to take a photo but tbh, its all bit worrying how this was done.
- Ratcatcher
What diam are your rear discs, i wondering if a smaller disc has been fitted to allow the clearance...
- patriot66
Have a read through this post from quite a few years ago. All brake sizes and combinations described in detail
viewtopic.php?t=8399
- Liam22
What are you painting those discs with? Does it last?
- patriot66
Black and Blue Hammerite Smooth. It loses its shine slightly over time but it never flakes, chips or rusts through. Looks much better than red rust
- Liam22
