Cheap Brakes Upgrade
- kis
I’ll take a look at the e46 route. Good shout TomK
My E85 Z4 3.0i SMG
1 Series - E87
4 Series - F36, F82 M4
5 Series - E34 (x2), E39
7 Series - E32
X5 - E53, E70
X6 - E71
1 Series - E87
7 Series - E32
X5 - E53, E70
X6 - E71
- Vanne
Id be in for a set as well Gazz
cheers, lovely work mate
2007 EuroSpec Z4///MC Building/Developing Z4 GT3
Powered by Severn Tuning
- ph001
I must be missing something here. How does a backing plate upgrade the brakes?
Cooling duct.
I'd be up for a set if they fit the 3.0si - one of mine has recently become unattached to all three bolts!
- ph001
Ok, I get the cooling duct bit, but am still at a bit of a loss as to why the backing plate makes much of a difference???
- TomK
The backing plate is designed such that it allows a hose to be attached that is connected from some entry on the front bumper which vents cool air directly to the centre of the disc. The centrifugal vanes of the disc pull this air through the disc allowing much much better management of disc temps. My discs on track are getting to around 600c which is a little on the high side and whilst removing the oem ones completely may help a little this would expose the ball joints to these temperatures directly. The standard Z4m air 'ducts' in the fangs do bugger all for getting cold air even into the wheel well.
There is a great write up on here by exdos with another perhaps slightly cruder (in terms of the backing plate) diy for a similar idea.
- ph001
Now I get it. Thanks for explaining.
