Is my top fully open?
markalp
Post by markalp » Thu Dec 07, 2017 6:20 pm
I think it isn't fully open, but the wife thinks it is.
Alpina Roadster S LUX #030
obewan
Post by obewan » Thu Dec 07, 2017 6:39 pm
Thinking back to when I had one I'm pretty sure it was flush when open - doesn't the red light flash if not fullyclosed/open?
E89 2.0 SDrive MSport/Suzuki GSX 650F.
Gone but not forgotten E85 2.0 MSport
firebobby
Post by firebobby » Thu Dec 07, 2017 6:41 pm
Looks ok to me
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
markalp
Post by markalp » Thu Dec 07, 2017 6:45 pm
No red lights are showing on the button panel, and i am sure it used to be flush as well, but the wife insists it has always been like that :/
I only noticed it when I took off the wind deflector, and that 1cm gap has been annoying me ever since, checked all the folding straps are there and working, the hinges have been greased, so i'm at loss.
markalp
Post by markalp » Thu Dec 07, 2017 6:46 pm
Looks ok to me
Don't spose you have any images of yours with the top down do you?
Ducklakeview
Post by Ducklakeview » Thu Dec 07, 2017 6:48 pm
That's fine.
Mike
buzyg
Post by buzyg » Thu Dec 07, 2017 6:51 pm
That looks about right though not too neat.
And if you do need it pushing down a touch, there is a solution.
:D :wink:
ph001
Post by ph001 » Thu Dec 07, 2017 6:54 pm
<Edited due to talking bollocks>. Be nice to see a pic from the side showing how flush the rear edge is with the boot trim.
2004 E46 M3 coupe manual.
Monkeydonkeyratmagic
Post by Monkeydonkeyratmagic » Thu Dec 07, 2017 7:47 pm
It is fine but not as intended. Just before it stops give it a little bit of help down and it'll click. Push that button at the top of the rear console and it'll take the latch off and rise to that position. Mine is exactly the same as that. Holds up at 110mph just fine (off road of course) without wind deflector.
Soon to be nice E85 2.5i
265BHP Fiesta ST, 5.5s 0-60 / 11.7s 0-100MPH.
Ducklakeview
Post by Ducklakeview » Thu Dec 07, 2017 7:54 pm
No red light on face lift if not fully open as the switch between the roll hoops was deleted (not sure about the Alpina). Be nice to see a pic from the side showing how flush the rear edge is with the boot trim.
There is no switch between the roll hoops, on any of them. The roof gets told it has competed opening by the hall sensor on the passenger side ram/hinge, at this point the roof control ecu signals the locking catches to close. This also extends the front latching tab, which slides forward into the slot on the bracket between the hoops if there is one fitted, but obviously on the later cars with no bracket, the tab doesn't lock into anything.
The flashing red light is a signal that either the hall sensor hasn't reached it's closed position, sometimes because the bracket between the hoops is catching and stopping the roof from dropping down, or because you've not kept your finger on the button until it's completed the whole procedure INCLUDING raising the windows.
A lot of them just click into place once you've driven off, owing to the vibration causing them to "settle" into the fully stowed position.
Mike
ph001
Post by ph001 » Thu Dec 07, 2017 9:22 pm
Apologies I was getting the switch mixed up with the latch! :headbang:
Crazy Harry
Post by Crazy Harry » Thu Dec 07, 2017 9:28 pm
Looks fine to me - but to be honest I don't pay much attention to things behind me; either I've passed it or its not caught me up yet!
Anyway top down in December - well done sir :thumbsup:
john-e89
Post by john-e89 » Thu Dec 07, 2017 10:07 pm
Hers is......
Sorry, couldn’t resist.... :roll:
2015 E89 35is. Sapphire black on 296's, coral red, nav, cruise, pro wireless, comfort pack and toasty steering wheel.
Previous:
Z4M roady
E85 3.0 si,
E85 3.0SE
No 5 has landed...2nd ///Mental angry roller skate...
firebobby
Post by firebobby » Thu Dec 07, 2017 10:40 pm
Looks ok to me
Hard top is on now, so can't take a photo, but yours looks fine :thumbsup:
Toyota MR2 NA 1995
markalp
Post by markalp » Fri Dec 08, 2017 12:55 am
Hmmm I think tomorrow I am going to half open it then switch to manual and try and open it all the way by hand, that last 1cm really does grind my gears.
If it is catching on the latch and not dropping down completely Im guessing I can just get the catch removed without issues as the facelift model doesnt have one. However having said that I do like the autobahn and have been known to pass 140ish at times, would that be a problem? (would the wind suck the softtop open if its not latched properly)
Who is online
Users browsing this forum: Baidu [Spider] and 44 guests
