What is this thingy
NickDE
What is this thingy
Post by NickDE » Fri May 19, 2017 11:45 pm
Whilst grovelling around in the passenger footwell installing Cruise Control wiring I found this thing connected to the wiring but hanging loose behind the trim below the glovebox. Does any one know what it is ?
Darkness gone, go Darknes2, go Frozen, go Tronic
Smartbear
What is this thingy
Post by Smartbear » Fri May 19, 2017 11:49 pm
Doesn't look oem, maybe a tracker or a flux capacitor? :?
e89 Sdrive2.0 18i which has apparently turned into a 20i :D
e89 Sdrive3.0i this ones busted, pass me another
e85 3.0si-sold my trouble free car...
firebobby
What is this thingy
Post by firebobby » Fri May 19, 2017 11:52 pm
Looks like the foo foo valve :|
Toyota MR2 NA 1995
Triumph GT6 1972 (project)
Young Pretender
What is this thingy
Post by Young Pretender » Fri May 19, 2017 11:55 pm
Saftval GPS tracker.. according to google
Ever get the feeling you are being watched :o :P
NickDE
What is this thingy
Post by NickDE » Fri May 19, 2017 11:58 pm
maybe a flux capacitor? :?
Now that would be nice. How do I control the TTS (Time Travel System) ? I couldn't find any settings for this in Carly :?
NickDE
What is this thingy
Post by NickDE » Sat May 20, 2017 12:01 am
The current status of the Foofoo Valve is impressive and forward-looking: an atomic-powered version is planned to be carried on the 2016 Dream Chaser shuttle flight from Kennedy Space Center. One of the flight crew, Payload Specialist Gorge Foosamos, will be responsible for the maintenance and deployment of this wonder of modern science, in the hopes that all mankind will benefit from having this extraterrestrial Foofoo Valve orbiting the Earth.
firebobby
What is this thingy
Post by firebobby » Sat May 20, 2017 12:06 am
:rofl: :rofl: :rofl:
Can I have what your drinking :D
Toyota MR2 NA 1995
NickDE
What is this thingy
Post by NickDE » Sat May 20, 2017 12:09 am
Now that is scary. Who is tracking me ?
I'm guessing that removing this thingy may be more hassle than it is worth. I assume it is wired in in such a way that just cutting it out will cause something to break,
NickDE
What is this thingy
Post by NickDE » Sat May 20, 2017 12:10 am
Sure, I just e-mailed you a glass.
Stuartt
What is this thingy
Post by Stuartt » Sat May 20, 2017 6:37 am
IRC it will have three wires, live, earth and an antennae your best option if you want to remove it is to trace the wires and disconnect them where they tap into the wiring harness. Don't just chop through them.
If it looks any harder than that just tuck it back up and forget about it. Believe me if no one is paying the subscription they are no longer monitoring it.
Hope this helps
Stuart
04 3.0i SE Manual Roadster in Sterling Grey, Pro satnav, Xenons, MM Tips, Gaptech RCH+, LED side lights, stubby, multifunction steering wheel,AUX in Cruise Control, Clear Third Stop Lamp, CDV delete, Cup holders, ZHP Aero boot spoiler Aero side skirts
sticky
What is this thingy
Post by sticky » Sat May 20, 2017 6:58 am
Hope this helps
Stuart
Like he says, nobody paying = nobody tracking. On the other hand it could be useful if you can find out who to subscribe to if you want use it
03, 3.0 i . Gaptech, roof motor new/re-located
Young Pretender
What is this thingy
Post by Young Pretender » Sat May 20, 2017 7:54 am
Is your wife keeping tabs on you? :lol:
Steve84N
What is this thingy
Post by Steve84N » Sat May 20, 2017 8:07 am
Probably worth removing to save battery drain though?
C63 AMG Estate 6.2l
Matt64
What is this thingy
Post by Matt64 » Sat May 20, 2017 8:14 am
You need the hyper space upgrade for that. Waste of money, they put the button in the boot! You press it, car zaps off to a different dimension, leaving you stranded. - maybe it was intended for kidnap victims. :-D
2004 Merlot 3.0i SE. Pretty sure I'd rather drive it than polish it.
1993 Mk1 Mx5 S-LTD Home brew turbo conversion. :fuelfire:
NickDE
What is this thingy
Post by NickDE » Sat May 20, 2017 9:55 pm
Thanks for all the input. I had another look at the wiring and although not too complicated I decided I couldn't be arsed taking it out, so it has been tucked away safely again. And maybe it will function as a Flux Capacitor in the future !
Who is online
Users browsing this forum: Buckz, Darkangelv2, hopz121, markplant, maxman, thanatu55 and 27 guests
