S54 Inspection 2 + Rod Bearing Service
- R60BBA
Been quoted £1,400 for the following work:
Inspection 2
- engine oil + filter
- microfilter
- air filter
- spark plugs
- valve clearances
- differential oil
- gearbox oil
- coolant flush
- subframe check
Rod bearing service
- new shells
- bolts
+ labour
Is this about right?
(Yes I know this is for an M3 and not a Z4 but so far I have found that people are quite unresponsive on the Cutters forum)
Inspection 2
- microfilter
- air filter
- spark plugs
- valve clearances
- differential oil
- gearbox oil
- coolant flush
- subframe check
Rod bearing service
- new shells
- bolts
+ labour
Current: 2002 E46 M3
Current: 2004 R53 Cooper S
Current: 2005 997 Carrera S
Gone: 1998 E31 840Ci Sport
Gone: 2007 Z4 E86 3.0Si Sport
Gone: 2015 F21 116d M Sport
- ph001
Yeh, I think that's pretty good actually - is that with Redish?
- R60BBA
Nah BMS Surrey.
Car was actually booked in on Friday but had to cancel and now Kev and Lee are on holiday until August!
Sounds spot on
- Spaniarduk
What's the mileage of your M3?
Volando voy
Volando vengo
Volando voy
Volando vengo, -engo
Y por el camino
Yo me entretengo
Volando vengo
Volando voy
Y por el camino
Yo me entretengo
- R60BBA
75k, any particular reason for asking?
Out of curiosity, how much is the labour on the job? What sort of mileage do I need to be thinking about a rod bearing service?R60BBA wrote: ↑Tue Jul 10, 2018 11:36 am Been quoted £1,400 for the following work:
Inspection 2
- microfilter
- air filter
- spark plugs
- valve clearances
- differential oil
- gearbox oil
- coolant flush
- subframe check
Rod bearing service
- new shells
- bolts
+ labour
Current - Ruby Black MR
- R60BBA
Not sure, the quote was all in.mark seeker wrote: ↑Tue Jul 10, 2018 12:41 pm
General consensus is every 80,000 - 100,000 miles, but this can depend on a number of factors (ie how often the oil has been changed, what type of oil has been used, whether the car has been warmed up before using full throttle etc)
- bmwaddict
I paid that for inspection2 and Rod bearing shells at my Indy, sounds about right
I think the rod bearing shells labour is about 500 ish with about 450ish of parts from what I can remember, CPC charge around £975 in total. Get them to check the engine mount bolts as they like to work themselves loose!
Currently zedless
'07 Mugello Blue Audi B7 RS4 Saloon with added goodies
'94 Black/Silver/Green Honda CBR400RR
Previous:
'07 Ruby Black Z4MC
'07 Sapphire Black Z4C 3.0si Sport
Previous:
'07 Ruby Black Z4MC
Do they measure the Crankshaft for ovality and wear before they renew the con-rod bearings, not forgetting does the con-rod also get measured to make sure that it is within tolerances?
