Tar Remover...white drips
Claying, polishing, waxing... share your secrets in here.
ihadablackdog
Post by ihadablackdog » Sun Sep 27, 2020 6:06 pm
Washed our cars this weekend for the first time since March (I know, shoot me now!).
Both are alpine white (Debs is a 116d and mine a 20i Z4).
Both are covered in tar spots but mine is awful.
They need a full on decontamination job with tar remover, fallout remover, clay (Mit?) etc etc and whilst I have the stuff, I just can't be arsed.
Doesn't get more honest than that!
From a few meters away they look lovely now they've had a wash, but step closer and they are a bit nasty.
The last time I used tar remover when leaving to dwell, the drips coming off were chalky white in colour, as if it was dissolving the paint! From memory I'm sure this was at the tar stage, not fallout remover stage (but might be wrong).
So is this correct, or was it melting my paint or what? It dried on the driveway and stained it for a while.
Cant remember what products but is it common?
I'm thinking of taking them to the local koso-wash and just getting them to do those two stages, or actually just the tar removal.
2011 E89 sDrive20i
Smartbear
Post by Smartbear » Sun Sep 27, 2020 6:37 pm
I use tardis tar remover & it definitely doesn’t dissolve the paint! It’s not that hard to do, get some motivation :thumbsup:
e85 3.0si sold
ihadablackdog
Post by ihadablackdog » Sun Sep 27, 2020 6:57 pm
But does it drip white?
I think it was tardis I used, also some Car Chem stuff at some point in the past.
2011 E89 sDrive20i
Z4C_er
Post by Z4C_er » Sun Sep 27, 2020 7:29 pm
I think Kero drips white. Tardis may have kero in it. I know it sounds heavy duty, but you can 'mix'/add some kero in water and rinse the tar spots off yourself. just wipe them off then rinse straight off.
2006.5 E86 Z4C si SE Phoenix Yellow
ihadablackdog
Post by ihadablackdog » Mon Sep 28, 2020 8:50 am
What is Kero?
Kerosene?
2011 E89 sDrive20i
GAZA62
Post by GAZA62 » Mon Sep 28, 2020 5:27 pm
I've used AG ITR in the past no probs with that product and no need to let it dwell you can see the tar start to run down the sides of the car almost straight away i think it removes any protection that you have applied so best to use before a full detail.
T.SILVER 2004 3.0SE AUTO
IF IT WAS NOT FOR BAD LUCK I'D HAVE NO LUCK AT ALL
Smartbear
Post by Smartbear » Mon Sep 28, 2020 6:13 pm
ihadablackdog wrote: Sun Sep 27, 2020 6:57 pm But does it drip white?
I don’t have any drips, just dampen a microfibre with it & it does the job :thumbsup:
e85 3.0si sold
Z4C_er
Post by Z4C_er » Mon Sep 28, 2020 6:51 pm
ihadablackdog wrote: Mon Sep 28, 2020 8:50 am What is Kero?
Kerosene?
Yes, sorry, 'kero' is kerosene.
ihadablackdog
Post by ihadablackdog » Tue Sep 29, 2020 11:49 am
So I ordered some of the tardis yesterday from autosmart.
Also got some of their wheel cleaner/fallout remover.
....and some other bits from clean your car.
Rob...if you put it on a cloth do you have to rub it much? I’ve tried that in the past and it never really seemed to do much. Don’t forget, at the moment I’ve got loads, not just a few spots.
I’m thinking of spraying it on and having it melt the tar like gaza62 says.
2011 E89 sDrive20i
Smartbear
Post by Smartbear » Tue Sep 29, 2020 2:46 pm
ihadablackdog wrote: Tue Sep 29, 2020 11:49 am So I ordered some of the tardis yesterday from autosmart.
My cars never been too horrendously infected, damp microfibre’s always worked well for me. Tar spots tend to harden and form a skin so a bit of elbow grease makes them disappear better than just spraying & leaving in my experience.
e85 3.0si sold
ihadablackdog
Post by ihadablackdog » Tue Sep 29, 2020 6:59 pm
Sounds like you keep on top of it, unlike me 😂
Do you re apply protection after? I use c2v3 so not a hardship to apply.
Weather looking crap for the weekend, that’s about right!
2011 E89 sDrive20i
Smartbear
Post by Smartbear » Tue Sep 29, 2020 8:13 pm
ihadablackdog wrote: Tue Sep 29, 2020 6:59 pm Sounds like you keep on top of it, unlike me 😂
Yes, the Tardis strips wax from the area worked on so i put something there even if it’s just a detailing spray.
e85 3.0si sold
ihadablackdog
Post by ihadablackdog » Tue Sep 29, 2020 8:17 pm
Thank-you
2011 E89 sDrive20i
GAZA62
Post by GAZA62 » Wed Sep 30, 2020 5:35 pm
Sorry OP i should have said i did not spray it on i used an MF cloth which i had squirted the ITR onto then worked the tar spot which caused the tar to run down the bodywork but i find i never seem to get any tar spots on the Z may be due to all the layers of protection
ihadablackdog
Post by ihadablackdog » Wed Sep 30, 2020 8:10 pm
The Tardis arrived today along with a load of other shiz. Putting it in my "detailing products" cupboard in the garage I found a bottle of Meguires stuff :headband:
I think the key is to keep on top of things, so a few small spots each wash instead of ignoring it and then having lots build up. And they've been there a while so well stuck on I guess.
Do you just buy cheap sacrificial MF cloths and just bin them when they eventually get too manky?
2011 E89 sDrive20i
